Allis B hydraulic |
Kiwi
Joined: 23 Jan 2018 Location: New zealand Points: 393 |
Topic: Allis B hydraulicPosted: 27 Oct 2021 at 8:56am |
Hi all I have just about finished my B restoration and had it running for the first time today and worked the hydraulics the ram went out but I can’t get it back in even with some weight on it the lever is in the down position. I don’t want to start pulling things to bits Willy nilly because of the new paint job were should I be looking first.thanks for your help in advance
Tractors Allis EB,two C,diesel G
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5279 |
Posted: 27 Oct 2021 at 12:07pm |
If the packing nut is too tight, that will cause that.
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 90897 |
Posted: 27 Oct 2021 at 3:59pm |
You can use a bar clamp to push it back in... best to have an implement on the tractor and its weight and mechanical advantage should push it back in. Paul is right, the packing it holding it.. they get old and hard.... might still be OK once some weight on it... 200 pounds might not be enough.
