Swap HD5G idler bearings |
WaltDevore
Joined: 03 Jan 2020 Location: IdahoSprings CO Points: 143 |
Topic: Swap HD5G idler bearingsPosted: 26 Oct 2021 at 7:33pm |
After good workout with track wrench I got enough slack to pull the track off. Is it feasible to try to home make press to remove shaft, and, if possible, is installing the bearing in the replacement idler possible for a rank amateur? Thanks for any ideas! |
Les Kerf
Thanks(1)
Posted: 26 Oct 2021 at 7:54pm |
Once you get the shaft pressed out the rest is easy; you may need to re-adjust the shims for proper bearing clearance but that should be minimal.
We ran our press up to 40 tons of force as registered on the gauge to get my Son-in-law's idler apart. Good luck! |
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42249 |
Posted: 26 Oct 2021 at 8:35pm |
At that point i bought the cups but could not find the cone bearing and said it's going to the shop where they know what they are doing as they also had the bearings
Ended up dropped it off one day and picked it up the next . |
