100/200 Series Tilt Wheel ?
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Topic: 100/200 Series Tilt Wheel ?
    Posted: 20 Oct 2021 at 8:30pm
How many of you guys utilize this feature on the old gals ?
Was this available on any smaller  model than the 190 ?  Thanks
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2021 at 9:45am
I use it on my one ninety/one ninety XT.
On my XT however, it needs to be snugged up a bit, as the steering wheel keeps settling to the down position
Darrel
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2021 at 10:12am
I use mine when I stand up and drive.
Don't think it was on lower models. The 190 was very progressive!
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2021 at 9:35am
I set mine to the position I liked and haven’t moved it since. Neat feature for a tractor back in the 60’s to have. Can’t think of any tractor before that having it. I know AC pushed that feature in their literature and dealer movies. Not sure how much of a selling point it was but it was all about the console control and large floor area designed for comfort. And it is a comfortable tractor to operate so they got it right in my opinion.
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2021 at 3:51pm
I'm not sure if was available on smaller AC 100 series. I've only owned 5 180/185 none of them had it. The tilt and extend is nice in 200's, changing position on long days helps.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2021 at 6:58pm
LMAO !! I put the seat up into the "2,nd" position without  hoisting the entire seat assembly  through the "notches" of the incline WinkWinkBig smileBig smile !!
Yes , ALLIS was  WAY ahead of the competition back "then" far most of their products, the PTO ( non -live)  should have been addressed in the "early" '60's IMO Confused
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2021 at 9:30pm
I have that on my 200. With the factory cab, I can't stand up and drive. It works but I've never moved it after I set it several years ago.
Ky.Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ky.Allis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2021 at 10:22pm
My 200 has tilt and telescoping steering wheel. Were both features included in same option or was it available with tilt only? I use the telescoping feature quite often but rarely change the tilt.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2021 at 7:35am
I remember the telescope feature as an option and maybe not on the first 200's, but later on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2021 at 9:45am
Now my curiosity is building; have to see if my newly aquired 200 has telescoping steering wheel.
I know that it has tilt
Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ky.Allis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2021 at 4:21pm
After looking in parts book on my 200 it appears the telescoping feature started with Ser.#4001
That's the same time the 200 changed to the "Gated" PD control. These are the 200's some people refer to as "price cutter" models even though they had upgraded PD control and valve and offered telescoping steering wheel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2021 at 5:52pm
The 200's replacement, the 7000, had the telescope steering wheel as an OPTION.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2021 at 6:39pm
[/QUOTE]
Oliver had a tilt/telescopic steering wheel starting in 1960, AC didn't have it until 4 years later. AC was a bit lagging behind on this feature, as well as the mentioned TRUE IPTO.
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2021 at 6:28pm
I finally remembered to look at my 200 to see if it has telescoping steering wheel; it does, and it works ‼️😃
Darrel
