1953 Allis Chalmers CA Ross steering box
1992ultraclassic View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1992ultraclassic Quote  Post ReplyReply Direct Link To This Post Topic: 1953 Allis Chalmers CA Ross steering box
    Posted: 11 Oct 2021 at 4:30pm
Trying to restore father-in-laws CA. Bushings are worn and knobs on the shaft that ride in the worm gear also worn. Anyone know where I can get a good box or parts to rebuild this one? Thanks
Rick
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2021 at 6:02pm
used boxes on e-bay are very high priced.  The PINS are available individually to replace - on e-bay and others... you can get bushing of any size from McMaster Carr online.
Edited by steve(ill) - 11 Oct 2021 at 6:12pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2021 at 6:14pm
ROSS boxes were used on a variety of trucks / cars / tractors... There are a couple different "SIZES" that were used... Here is a reference.. You might talk to them about the SIZE and compare to yours.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2021 at 6:23pm
TRW/ ROSS manual series ....... parts diagram
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2021 at 7:30pm
I rebuilt the Ross steering box for my G last winter.  All the parts were available through Steiners.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2021 at 6:50am
The G steering box shares many parts with the B. The CA box is unique to itself.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2021 at 1:25pm
Rick, if you have any luck getting parts for the CA box rebuild.. please post back.... im sure people would like to know where / what you found that fits.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1992ultraclassic Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2021 at 9:10pm
Good evening,
Sorry that it has been a bit for me to answer back, but was trying to find options. Not all I had hoped for, but some progress.
Oreilly crossed the oil seal for the levershaft to a National 340356.
I got 2 split bushings from Bailey International. Part number 20NU20. Unfortunately I couldn’t find 1.25IDx1.375OD so I had to get 1.40OD and turn them down in a lathe. Turned them to 1.377 and after pressing them in honed them to a nice slip fit to the shaft.
I couldn’t find the correct levershaft pins. Ordered some for a B hoping I could make them work but the part that would ride in the worm gear was too small. I ground the heads off the original ones and turned them 90 degrees and welded them back in. Definitely better than it was as they were very worn on 2 sides, but wish I could have found new ones while I had it apart.
Much tighter and consistent now thru the turning radius.
Lots of rebuild kits for smaller shaft diameters used in Jeep’s, but not for the CA’s.
Hope this helps someone.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2021 at 9:48pm
Thanks Rick... i was hoping one of the vendors could match up some old Jeep parts... guess there is no luck on that.
corbinstein View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote corbinstein Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2021 at 6:42am
turning them 90 degrees is an old Studebaker trick. that's what we did.
