7 grand
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Topic: 7 grand
    Posted: 09 Oct 2021 at 9:54am
OK guys I got a new to me Allis 7000 a1976 model which apparently needs a lot of work to get up to my standards. First question is I have two leaky injectors number one and number two; I’ve ordered new copper sleeves and O rings for those two injectors. Can you tell me what kind of a tool I need to replace the copper sleeves with and where I can find such a tool? As always thanks to all! Dana
Blue Skies and Tail Winds
                          Dana
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2021 at 10:23am
Would think Agco should have something - Have heard a Cummins tool is close to redo the copper sleeves- or a Cummins shop can fix them
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2021 at 10:39am
hmm, should you also replace the other injector parts, while you're at it ??
My luck, fix 1+2 then 3 and 6 would leak....
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2021 at 12:29pm
You have to remove the cylinder head to do that. It's expensive and involved. Wouldn't be surprised if the head is cracked too.
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2021 at 12:56pm
I am not very good with the search system but in the past I have posted the tool spec sheet to install the sleeves.  If you can't find it, I can get them to you. Sent spec sheet to those that wanted to have a set made but have never heard if it worked out. Dale
Edited by orangereborn - 09 Oct 2021 at 12:59pm
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2021 at 1:36pm
“7 grand”. Is that your nickname for your new AC 7000? I still like “Mater” cause of it’s tow truck mirrors. Cars movie, Mater’s quote, “Ain’t no need to watch where I’m going,,, just need to know where I’ve been...”
Congratulations! Hoping your 2900’s head isn’t cracked. Regardless, I know you’ll have it purring to your satisfaction soon.
Just for fun...
https://m.youtube.com/watch?v=HA6xXNToFas
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2021 at 3:40pm
Ok how do I know if my heads cracked? Bicent Bandit is what the new decals say to go along with big sisters “Bandit “ and “Bandit II”
                          Dana
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2021 at 3:44pm
Lol AC7060IL
                          Dana
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2021 at 3:47pm
Next up are 7000 brakes same type as 200’s? I only got one🤷🏻‍♂️
                          Dana
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2021 at 4:37pm
Let's just slow down here, Bunky. You say injectors are leaking. Leaking what ???   If you're leaking COOLANT, you have a cylinder head issue and the head has to be removed to replace injectors copper tubes, OR the head is cracked, still have to remove the head.  Most of the time when someone says they have "injectors leaking" it is simply a valve cover gasket !!!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2021 at 6:23pm
Thanks Doc. Soon as I get home I will surely examine more closely as I should have done last night!
                          Dana
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2021 at 6:51pm
Just out of curiosity, Is this a cabbed machine? Does it have decent rubber and duals in the rear ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2021 at 7:00pm
Yup the one from Kokomo with an aux 3ph fuel tank full front weights duals tinted windows
                          Dana
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2021 at 7:07pm
Can you post a pic ?? If you were replying to me, I have no clue as to your machine, other than it "might" have come from Plevna ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2021 at 9:03pm
If injectors are leaking at copper seat, they will be clean and dust seal may be gone. If injector is leaking where tip cap screws on or valve cover leaking, it will be oily.               MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2021 at 7:33pm
In between flying more than full time…and building another 20x60 addition…are 7000 brakes like XT3 and 200 or? Thanks. Dana
                          Dana
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2021 at 9:58pm
Believe Dr Allis when he tells you to check the valve cover for leakage!
Sure glad I listened to him on that subject. A friend of mine who had the same issue, wouldn't listen to me, and pulled the injector.
Afterwards, he tightened the valve cover bolts slightly, and ate some crow
Darrel
Alex09(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2021 at 12:06am
7000 brakes are disk brakes like late 200
www.awtractor.com
A&W TRACTOR 920-598-1287
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2021 at 12:10am
Dana, as Dr says. Check for what leaks, oil is likely from Valve Cover Gskt, bolts work loose and leak, can tighten them 1 or 2 times then needs gskt. If that's your leak there's a update for the cover bolts it's part #74036974 it was started in early '82. The Valve Cover Gskt is #74008074. I've done 5 - 6 on 100 series over 20 yrs, so far no leaks. IF it's diesel fuel leaking check the return line fittings for leak before pulling injectors.
I use a couple cans of brake cleaner to help dry up area leaking, then run a few hours.
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2021 at 5:28am
Oh believe me y’all I listen to our Doc! And Mack! And y’all! I’m too busy like I said flying and building ano5er tractor storage building BUT we lifted the side cover off of Bicentennial. Bandit and sure enough it looks and smells like OIL! But my concern is still…she just didn’t sound right…. So we shall see when the time comes I will dive into this project. Thanks so much to all. Dana
                          Dana
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2021 at 5:32am
Previous owner said the injection pump had not over 70 hours on a rebuild. When my rebuilt pumps return they look like new. This one on the Bicentennial Bandit doesn’t look like that so IDK maybe a garage Fix or nothing? Thanks Dana
                          Dana
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2021 at 7:37am
are we going to see a picture of the new tractor.
Where abouts are you putting the new shed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2021 at 5:21pm
Building "ANOTHER" storage barn ??? ConfusedConfused
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2021 at 5:25pm
Mikez I’m adding westward When the weather turns cold her and things calm down a bit you’ll have to come up with your dad
                          Dana
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2021 at 10:09am
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2021 at 10:32am
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2021 at 11:05am
Does that bother you for some reason?  Or is it just confusing?
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2021 at 7:14pm
My comment on "another barn" was aimed at his "growing"  wealth of  OLD ORANGE Big smileBig smile !!
Kudos to the Captain for using/ sheltering these works of art IMO ClapClap
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2021 at 3:17pm
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2021 at 9:49pm
Looks good. Did you get your leaks stopped? what were they?
