Ear corn stock tank test
clarkscreek View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote clarkscreek Quote  Post ReplyReply Direct Link To This Post Topic: Ear corn stock tank test
    Posted: 27 Sep 2021 at 4:11pm
I know I've heard about putting ears of corn in the stock tank to tell if it's ready but when I Google it I get conflicting answers. What do you guys do or did to determine if ear corn is ready for the crib. I've used my moisture tester for shelled in the past but was going to try another method and then compare.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2021 at 5:27pm
Back when we picked, seems dad would just break a few ears, maybe bite a few kernels. He knew. Of course half the time it was thanksgiving weekend.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2021 at 7:05pm
We never picked any corn until all of the stalk has lost it's green and the ears dropped.
SLee(IA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SLee(IA) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2021 at 10:46pm
Toss some ears (without husks) into the tank. If they sink, still to wet to pick. If they float, time to pick. At least that's what I was taught 60 years ago.
Steve
allisbred View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisbred Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2021 at 3:34am
Checking it by the kernel is what we do, remember the cob can hold a lot of moisture depending on variety. If you have the narrow cribs for storage, they can take the wettest, round wire don’t breath as well and will need to be a little dryer to prevent mold. In any event, we pick corn around 18% so it does not shell as much with a new idea picker and that doesn’t leave a husk on. If the ear twist at the kernels, it can be picked. Shelled corn needs to be a little dryer if storage is a bin.
Edited by allisbred - 28 Sep 2021 at 3:54am
Joe(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2021 at 7:42am
I usually go for 3 out 5 or 5 out of 7 floating.  Picked that way for over ten years and havent had a crib issue.
Life is simpler when you plow around the stump.
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote clarkscreek Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2021 at 7:49am
Joe, have you ever checked kernel moisture after that test?
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisbred Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2021 at 8:14am
What is the average moisture reading of that floating corn? I’m going to go on a rant and give my opinion only. Have been working in feed dust think since I could stand, spent (2) full weeks in the hospital damn near dead in 1988 after grinding moldy corn for years. My father checked all grain with the bite test, hay with the crack test back then as he didn’t have the correct tools. When I started play farming, I bought moisture checkers for grain & hay! Guess what, no more dust that will eventually shorten your or those helping you lives. You will have better quality, learn a little on later developments for processes and not be disgusted with spoiled batches. I even learned that I can make hay better in the fall cool weather if the humidity is low. Learned as mentioned that ear corn will keep good at 18% depending on a few variables. All those old methods have a base that is approximately close, but we have better tools available now at a low cost. Sorry about my rant. Kevin
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote clarkscreek Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2021 at 9:26am
I was going to use the new tool, I was going to test some with old methods and then compare to my tester just for a fun experiment.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisbred Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2021 at 10:58am
What you have been doing is the best method in my own opinion. Would be nice to compare for shows and such though. I know that was a little rant but would like to teach people the best methods so they don’t cut important corner to save a buck.
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote clarkscreek Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2021 at 11:24am
I understand this is just for fun.
