Allis Chalmers G for sale |
earlybird847
Joined: 24 Sep 2021 Location: lake elmo mn Points: 15 |
Topic: Allis Chalmers G for salePosted: 24 Sep 2021 at 10:58am |
serial #G29512, hydraulic lift,front and rear cultivators, 4 speed transmission, pictures available, 25 gallon sprayer w/separate battery, good runner and ready to use
earlybird847
Posted: 24 Sep 2021 at 8:48pm |
ANY clues of what this might be worth to a collector, restorer or user?
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7574 |
Posted: 24 Sep 2021 at 9:13pm |
Still very handy as a user, but price cannot be determined without knowing its condition, even for a collector or restorer. Pictures would help. Has anything been done to the engine (or does it need anything)? How are the tires? Is the steering loose? Is the sheet metal banged up? All these directly affect price.
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 89286 |
Posted: 24 Sep 2021 at 9:25pm |
You dont see too many below $1500. and you dont see too many over $4000. Like he said, depends on condition / tires .
Lon(MN)
Joined: 11 Sep 2009 Location: Merrill Wi Points: 2043 |
Posted: 25 Sep 2021 at 5:26am |
Working factory hydraulics is a $500-$1000 plus.
earlybird847
Posted: 25 Sep 2021 at 11:00am |
Thanks for our quick response. Engine is strong but no knowledge of overhaul. Metal is straight but needs power wash, wire brush,primer, and paint. Rear tires look great, most likely replaced before I bought it. Front tires appear to be original. Steering is good enough for cross cultivation which consider very excellent. I have a number of pictures available to Email to interested parties. Is that the only reasonable method to provide these?
earlybird847
Posted: 25 Sep 2021 at 11:11am |
In the last 30 plus years i have only seen 4 or 5 under $1500 and about the same amount over $4500 What I have not seen is HYDRAULICS. That is what made this one so useful to me. How rare is hydraulics and does that mater to restorers or collectors?
earlybird847
Posted: 25 Sep 2021 at 11:13am |
earlybird847
Posted: 25 Sep 2021 at 11:26am |
I believe the high end for a real serious user. Any idea of how many were made and which years. I suspect it has collectable value also. I have bought and used several G's in my hobby garden farm. This was the most recently purchased, the best, and the last to be sold as I retire from this phase of life.
earlybird847
Posted: 25 Sep 2021 at 11:31am |
Thanks for opinions on value of Hydralics.
Dusty MI
Joined: 13 Sep 2009 Location: Charlotte, Mi Points: 5060 |
Posted: 25 Sep 2021 at 7:17pm |
The G uses the same transmission the B & C uses. And the same engine the Massy Harris Pony, The casting is a little different.
earlybird847
Posted: 27 Sep 2021 at 8:20am |
Planning to ask $4600 for tractor, sprayer, cultivators, hillers and parts box. Call 612-450-9299 if interested and needing pictures or other information.
earlybird847
Posted: 01 Oct 2021 at 9:34am |
This is a good strong worker for medium size vegetable garden. Also have a TroyBilt horse tiller with new Honda Motor. Pictures available on Craigs list Minneapolis.
earlybird847
Posted: 29 Oct 2021 at 1:10pm |
What might anyone know about availability of a rear gang hydraulic lift cylinder for an Allis G cultivator and how it replaces or assists the lever lift?
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5197 |
Posted: 29 Oct 2021 at 3:02pm |
Everyone is entitled to their opinion. The one G with hydraulics that I had was the worst tractor I ever used. Reason being: the way the tractor's steering wheel is designed you steer with your left hand, where is the hydraulic lever, down under the seat on the left side. Fine for a 1 armed paper hanger.
On a manual lift tractor the lift is done with you right hand, so no need to let go of the steering wheel. If the balance spring is set properly and attachment is easy to lift with the hand lift. If someone was giving me the choice of a single B tractor with various implements or the same G implements with a tractor attached to each so as to never need to switch things, I take the B with implements. I feel the G is only a toy to get attention at shows with. The G takes up just as much space as a B and can only do half the work at best. Then everything to repair a g will cost 2-3 time the same thing for a B.
earlybird847
Posted: 13 Jan 2022 at 7:02pm |
Thanks for all your help. My g has been sold to a vegetable farmer that should get great use from it. He has another one without Hydraulic lift and is excited to get his one with extra equipment besides. Thanks to those who bleed orange.
Dusty MI
Posted: 14 Jan 2022 at 7:38pm |
I have a "48 G, I have a pair of 12" left & right plows for it. The G is one of the best plowing tractors, although slow at covering much ground. It is very nice to plow with, the plow is right in front & under your feet, no getting a stiff neck cranking your head around looking behind watching the plow.
