HD5 steering clutch removal
Bradsdad View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bradsdad Quote  Post ReplyReply Direct Link To This Post Topic: HD5 steering clutch removal
    Posted: 23 Sep 2021 at 9:35pm
I'm trying to remove the steering clutch assemblies,the left side came right out but the right side doesn't seem to have enough clearance.I realize it only needs about 1/4" but I have about 1/16 AND IT WONT COMEOUT!!Any thoughts or advice would be appreciated.Thanks
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2021 at 7:21am
probably junk in the splines of the drum preventing it from sliding over 100%.  just gotta keep working at it.
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2021 at 12:21pm
Make sure all the bolts ben removed and with a big screw driver try to get more loose each side.
