D15 industrial diesel
elec View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote elec Quote  Post ReplyReply Direct Link To This Post Topic: D15 industrial diesel
    Posted: 23 Sep 2021 at 6:50pm
I have a d15 diesel. Serial number D15 4349D. It is a bare back. Wondering if the rear arms off of a d14 will fit so I can put a 3 point on it.
Side note for a good laugh: my father-in-law, a certified diesel mechanic, has been working on the d15 diesel for a few months now. He reinstalled the injector pump and it took him quite a while to realize the shut-off was backwards (pull to run, push to shut off) and that's why he couldn't get it to start!
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2021 at 7:20pm
Yes a D14 rear housing will fit onto a D15. You will also need the cylinder and most likely the pump under the power director, along with the traction booster spring/snap coupler. Unless it has a loader and you want to splice into that system to have just Lift/Lower without the traction booster.
elec View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote elec Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2021 at 7:34pm
Thanks for the quick response.
Yes it has a loader. I need a new valve on it to run the grapple so I will get a 4 spool valve. No need for traction booster. Do I need to cap off PTO whole or can I install a PTO shaft since I have a shuttle?
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2021 at 6:52am
The PTO in a shuttle equipped tractor will not run at the normal speed. If you are thinking of running a Brush-Hog, you're out of luck.
elec View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote elec Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2021 at 10:52am
No. Just want to keep oil in
