Should I buy her or not? Found a WD
Don(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Topic: Should I buy her or not? Found a WD
    Posted: 16 Sep 2010 at 6:14pm
Hey all, I have been looking all summer for a decent WD for my 2 row mounted corn picker, and I might have found one. Tell me what you think and if its worth it based on my description....
This I believe is a 1950 WD narrow front. It has been repainted and the paint is not that bad at all, there are some cracks on the back fenders where the bondo is cracking, but the rest of the metal looks to be in really good shape except for the front grill, which is dented in pretty good. But the front grill could be banged back out and look decent.
Two of the rims are questionable, where the rust has ate away the rim around the valve stem, but is holding air good right now, one front rim and one back. The tires are weather checked but are in fair condition and would work fine for me.
It is missing the water temp gauge, it has been converted to 12 volt (alternator) and the battery box is definetly not orginal. The muffler also needs to be replaced. The brakes also need replaced.
Alright, here are the two things I am concerned about. The tractor will not engage in 3 or 4th gear, and seems to be on the sloppy side. Is this a big job to rebuild the shifter? Do you think this is the problem? The other gears all engage and operate fine.
The other issue is that it seemed to run good, but had a couple times where she  sounded like it was missing on one cylinder. Other than that, it only smoked when the owner choked it to start the tractor.
I know this is a brief description, and you can't see what I saw tonight, but based on this, is the tractor worth $550?
Thanks! Don
Edited by Don(MI) - 16 Sep 2010 at 6:16pm
CJohnS MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CJohnS MI Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2010 at 6:23pm
Hey Don,
I remember you looking for a decent WD/WD 45.
You know, you can probably get that 550 back on selling just the engine, and you'd still make 200 - 250 in scrap metal on the rest. Not a kind way to look at it, but...
Dave A View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave A Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2010 at 6:35pm
thik it is worth it got $500 for my dads 10 years ago. not running with a cracked block and very bad tires. There was oin by Oshkosh with asickle belly mower the guy was asking $850 not running tires where rotted off plug wires were gone. Any tractor running is worth $550 unless it is a Ford 8N.
Play the game for more than you can afford to lose... only then will you learn the game.
Winston Churchill
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2010 at 5:01am
Thanks guys! Any other advise on how to fix the gear shift tower?
R Aiken View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R Aiken Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2010 at 5:10am
I know, send me some money and I will send you a good replacement. Richard
This page was generated in 0.311 seconds.
