B-110 Not Moving
Jonlaughlin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonlaughlin Quote  Post ReplyReply Direct Link To This Post Topic: B-110 Not Moving
    Posted: 18 Sep 2021 at 7:03pm
B-110 will not move. Drive belt spins but once shifted into gear tractor doesn’t move. About a year ago o had same issue and found that some of the gears were broken so I replaced them all amd it has run great ever since. Before I take the wheel off and open up the gear housing just thought I would check and see if anyone had any other ideas.   Thanks.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2021 at 5:18am
Sounds like a key has sheared between a shaft and pulley.
G
This page was generated in 0.052 seconds.
