Oil Viscosity??
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Topic: Oil Viscosity??
    Posted: 14 Sep 2021 at 7:33pm
The vehicle that I run calls for 5W20 oil, my wifes 5 year old 'newer' buggy calls for 5W30 oil. I would like to consolidate oils but am unsure which viscosity to stock up on Embarrassed Thanks
bemer848 View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote bemer848 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2021 at 8:01pm
Have you ever heard of google? Oh I forgot you are trying to get to the 4000 post mark.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2021 at 8:08pm
18 post to go !!  Your almost an ADULT !!!  Hug
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2021 at 9:36pm
Consult the owners manual of both vehicles, most give different ‘preferences’ of weights of motor oil. If both have a common grade in that list, go with that one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2021 at 9:51pm
manufacturers changed to 5W20 , a thinner oil, to help gas mileage. Most of those motors were originally 5W30 type....... If a newer auto requires 5W30, its normally because it works harder ( like a turbocharger) and needs a thicker oil for extra heat.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2021 at 5:47am
then there's the 'winter-summer' thing. you need different oil based upon the temperature..coruse with CC warming up the world, you won't need a 'winter grade' oil anymore.....
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2021 at 7:03am
Hunch only, but your vehicle is older, has some wear and some clearance, 5W30 would be just fine for yours.  And still 5W for easy flow at start up.  Do as you will.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2021 at 7:30am
I have a 2004 Ford Taurus, it calls for 5w-20, most of its life I used 5w-30 full synthetic. Tried 5w-20 a couple different times, but oil consumption always increased. So whatever mpg gain there may have been, was canceled out by the increased oil usage.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2021 at 7:34pm
Thanks . My 5.4 is pushing 195,000 miles, the wifes buggy is 128,000 . Her Nissan Rogue is not T/C though in response to another poster Smile . Thanks guys
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2021 at 7:36pm
I haven't changed viscosity between "summer/winter" since 1998 LOLLOL !!!
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2021 at 8:00pm
Over 350,000 miles on my 1999 Toyota 3.0 V-6 Camry.  1 quart in 5,000 miles.  Using Castrol 5w-30 GTX motor oil.  Never had to open remove the pan or heads.  Runs strong as a new one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2021 at 12:31am
Stock up on both. It’s not a good idea to use other than what the manufacturer recommended.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2021 at 6:29am
Ya, me neither.  There's usually a recommendation that covers a very large range of operating temperatures on anything I've owned for the last few decades.
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2021 at 9:11am
Some vehicles today require full synthetic,
but with 195,000, maybe you better not switch., just stock up on both oils.
 and just label them 'HIS' and 'HERS' just so you know which is which.
