Wd picker project
55allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Topic: Wd picker project
    Posted: 14 Sep 2021 at 10:54am
Hey a’ll,
Well I started another project: a WD with a 33 picker.
It has real good spark but won’t fire even with starting fluid so I’m completely lost of what to do.
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2021 at 11:10am
Is it timed right?
Joe(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2021 at 11:46am
Put some oil in the cylinders.
Life is simpler when you plow around the stump.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2021 at 1:27pm
JC, it ran when it was parked.
Joe, I put some PB-Blaster in the plug holes.
I put new old stock points on and cleaned and set them at .020”. Not sure if that right?
farmboy520 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmboy520 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2021 at 2:20pm
Made sure there isn't a mouse nest in the intake?
On the farm: Agco Allis 9695, 7060, 7010, R66, Farmall H, and Farmall F20 (Great Grandpa's)
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2021 at 2:43pm
That’s very possible, the air cleaner wasn’t and isn’t on it....
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2021 at 10:10am
I found the problems, I was one spark plug wire off and the carb is gummed up so I put a old Zenith carb that I took off my 49 Wd( I put a marvel schebler the 49 Wd) and it ran like a good Allis should!!
JimIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimIA Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2021 at 10:24pm
Did you install new spark plugs?  Seen that before with old plugs, spark very well when not in the cylinder but wouldnt work when in the cylinder.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2021 at 10:48pm
I switch them with a set I had sitting around for quite a while, I pretty sure they are new but they’re Champions so I will put Autolights in it after a while.
And like I said it runs like a good Allis should.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2021 at 9:27pm
I ordered a set of 13.6-28 tubes and took a rim in to my local welding shop to fix around the valve stem ( it had rust holes).
The tractor is still 6v so thinking of the pluses and minuses of putting it to 12v.
Napa can get the 6v battery for $101.99 bucks!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2021 at 10:19am
Well I got the rim back and painted both and got the one on, now it’s just trying to get the other side off and put the tire on. Both back tires had fluid in them...
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2021 at 11:26pm
I found out to day that the water pump leaks but it’s not lose, it just drips a lot.
I started the picker and everything was working and decently quiet, the blower fans aren’t hooked up yet so not sure how they hook up if anyone has any ideas or pictures? I think I got a hunch that the 6 holes on the back part of the frame rails have something to do with it?
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2021 at 5:57am
Grab a manual off Ebay. Helped me find the 12 million grease fittings on the picker
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2021 at 4:25pm
I was going to switch my WD to 12v until I changed out the battery cables to 1/0 wielding cables. What a huge difference!!! It spins the motor like a 12v. Left mine stock 6v. That was 3 years ago, still strong spinning it over. I prefer to leave it stock as it came from AC.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2021 at 10:04pm
How long have you had the 6v battery? I’ve heard that those battery don’t last long?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2021 at 6:00pm
3 years
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2021 at 6:01pm
I put a 6v battery tender on it in the winter
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2021 at 10:53pm
55,
Nice picker project! Have fun with the old girl. Items you found sound about right. I like them switched to 12 volt. But thats just me they will run and start very well on 6 Volt too.
Don(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2021 at 3:50pm
What a beauty and best of luck!
I can't remember how the blowers bolt on, but I leave the belt off mine inless it's picking. If you do a corn picker search on here and find some posts with my name, i probably have a picture of it for ya
Galatians 5:22-24
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2021 at 10:51pm
Well today I brought it home to try it out on some popcorn we planted as soon as it dries up a bit( it was a five mile trip and I drove it).
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2021 at 1:23pm
Looks good, do you have the side covers for the engine, I wouldn't pick any corn without them
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2021 at 2:02pm
Nice!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2021 at 2:54pm
Yes I do, I have them off to work on the tractor. Also have the front screen that covers the radiator shell.
I will get a picture of it with everything on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2021 at 3:21pm
I would guess once a picker got added to a WD it rarely come off due to the complexity of mounting it? Would be neat to watch it pick corn. Has to be a very noisy and dirty job running one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2021 at 8:27pm
The noise part I got a cured, I have head phones!!
Today I changed the engine oil and the air cleaner oil, found out it had a mouse nest in it... and no it didn’t make it in to the carb, I caught it before it did.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2021 at 11:24am
Here’s a picture of it with the shields.
Gatz in NE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2021 at 1:05pm
that's a great picture
Tim NH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim NH Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2021 at 1:53pm
I agree nice picture. Gavin what are you using for a wagon.
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2021 at 3:19pm
Yay, great picture
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2021 at 6:46pm
I got a wagon I think might work.
This page was generated in 0.207 seconds.
