H-3 Gas Crawler Dozer
BobPaulusCentrOH View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobPaulusCentrOH Quote  Post ReplyReply Direct Link To This Post Topic: H-3 Gas Crawler Dozer
    Posted: 07 Sep 2021 at 4:32pm
Have 4 cylinder gas, and was wondering if the 149 gas engine when used on this machine, had the full flow oil filter like D 15 Series 2?  If machine has full flow oil filter, does that mean it is a 160 cu. in. engine and not 149 cu. in.  gas engine?
Thanks in advance for a reply.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2021 at 4:55pm
my guess it's a 160..
sniff,sniif. always wanted one 'sister' to my D-14s.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2021 at 7:20pm
I have seen the full flow system on many 149 engines. Look at the serial number behind the air cleaner hose, or sometimes on the flange to the bellhousing on the upper left side and it will tell you the CID when it left the engine factory.
