2300 disc spool needed |
Post Reply ![]() |
Jmcneese00 ![]() Bronze Level ![]() Joined: 05 Sep 2021 Location: Columbia,TN Points: 3 |
![]() ![]() ![]() ![]() ![]() Posted: 05 Sep 2021 at 2:34pm |
I recently purchased an 8 foot 2300 series disc. It had a bad inner bearing on one of the rear gangs. I think I have found the correct numbers for the bearing and the flange but the short spool beside the bearing has been worn down and needs to be replaced. I believe the size I need is 2 7/8” and the shaft is 1 1/4” hex. Does anybody know where I can find one of these spools to order online or the correct part number?
Thanks! Jake |
Mikez ![]() Orange Level Access ![]() ![]() Joined: 16 Jan 2013 Location: Usa Points: 8735 |
call agco.
Bearing 70586143 Flange 70586144 with fitting Flange. 70586145 plain Spool. 70571749 long 3-7/8” Spool. 70571750 short 2-7/8”. If you don’t have an agco dealer I could help you. But shipping from ny won’t be cheap. |
Thank you! I have a Massey Ferguson dealer close that might be able to help me get them through AGCO. I might let you know if I can’t get that to work out!
Alvin M ![]() Orange Level ![]() Joined: 24 Jun 2018 Location: PA Points: 804 |
Agco has all the parts
yes I just recently bought some through agco
Post Reply ![]() |
