wtb
brodersen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote brodersen Quote  Post ReplyReply Direct Link To This Post Topic: wtb
    Posted: 01 Sep 2021 at 7:44pm
wtb dual wheels for r65 combineand fenders for wd45 located in western iowa
Adam Stratton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam Stratton Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2021 at 9:32pm
I've got a set of 20.8x38 rice tires on 20 bolt rims with the unverferth spacers that came off a 2188 Case. From what I can see in the unverferth catalog the diameters are the same, but the case threads are metric and gleaner is SAE. Think maybe you could use SAE bolts to the combine and the metrics on the duals...I put wide single 10 bolt wheels on the combine when I took them off. You would need to do your own research to confirm. I can text you pictures if you are interested. Asking $1750 for all 4 tires,wheels, and the spacers. Located in SWMO.
