ISO 226 BLOCK
danno067 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote danno067 Quote  Post ReplyReply Direct Link To This Post Topic: ISO 226 BLOCK
    Posted: 30 Aug 2021 at 9:21pm
Had a little mishap the other weekend. Broke #1 and #2 main caps and split the block from the main saddle to the deck. This was on a D17 block. So if anyone would have a good block they are willing to part with please let me know. Closer to Wis the better. Thanks.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2021 at 5:21am
Resized
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2021 at 3:44pm
I've seen a number of 226 engines break those main caps. More than likely you block isn't damaged. If not, Get a machine shop to make a new set (all 3) from solid steel and then line bore them to match the block. We had to do that on a 226 that was turboed a few years ago. We also made them thicker and used studs.
Edited by PaulB - 31 Aug 2021 at 3:45pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2021 at 4:46pm
OUCH... that aint good ..
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2021 at 3:20pm
I've got an early D17 block that I would let go, cheap. It is not the full flow oiling system like the later blocks, but I think that can be changed? Central iowa location.
This page was generated in 0.101 seconds.
