180 Hydraulic problems
Razor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Razor Quote  Post ReplyReply Direct Link To This Post Topic: 180 Hydraulic problems
    Posted: 30 Aug 2021 at 8:26am
Need help I have a 180 that pumps the hydraulic oil out of the transmission breather on the top of the transmission  every time it is filled ? I have changed the oil and filter and it keeps losing the Oil out the breather? When the oil is full the hydraulics work until it loses the oil.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2021 at 8:35am
Shift the Power Director lever into neutral or LOW range and if the problem ceases or is improved, the oil seal behind the Power Director clutch (transmission input shaft) needs replacement.
allisorange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisorange Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2021 at 6:03pm
Had that with are 180. needs seal like the Dr. said.
J.Carlson
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2021 at 9:23pm
The reason it needs a seal, is because the piston ring seals on PD are worn out and maybe the housing they run in.                        MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Razor Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2021 at 7:47am
Where can you get the seals do they still make parts ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2021 at 8:09am
An AGCO dealership !!  Three of 70243226 rings.....one of 70242704 retainer, 70235253 seal, 70235254 gasket, and 70250886 split gasket. There are a few other misc. Orings and gaskets behind the brake latch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Razor Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2021 at 1:09pm
Thanks for all the Help I take it it will be some work taking it apart to replace what's wore out  it is a bit of work ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2021 at 1:44pm
Tractor has to be split in two right where you check your hydraulic oil level.
