G engine block
Kiwi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kiwi Quote  Post ReplyReply Direct Link To This Post Topic: G engine block
    Posted: 28 Aug 2021 at 8:31am
Hi all I have a G engine block that has broken the bolts holes out where the draw bar bolts up to is there anyway I can weld them up and redrill the holes or is it a case of finding another block. Someone has fixed it up with what looks like JB weld and drilled holes on the flat piece about 2 inches back to fit the draw bar I would like to fix it properly any ideas thanks
Tractors Allis EB,two C,diesel G
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2021 at 10:40am
if you really plan to use the draw bar, or have an implement that uses the draw bar as a mount (disc plow, sickle bar mower, etc) I'd really be hunting another block, that spot is weak enough when in good shape!
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
This page was generated in 0.313 seconds.
