ISO, 80xx right side steps, the light duty one
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Topic: ISO, 80xx right side steps, the light duty one
    Posted: 25 Aug 2021 at 2:54pm
In need of steps for my 8050, battery side, the one made of flat metal not tubing. I've checked local bone yards and Heitman. PM me with info.
Thanks
Leon B MO
Daehler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daehler Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2021 at 1:15pm
So early style? There are one or two up at Colfax salvage in Iowa. I know I saw one still on a tractor when I was up there in early March.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2021 at 2:03pm
Not sure if it's early or late or an option. The 8050 with the lighter steps is an 84. The 82 8010 has the tubing style. Our 8050 and 8070 both have heavier tubing style, not sure of years right off hand.
 I have call into Colfax to see if they have one. Thanks
Leon B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daehler Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2021 at 2:56pm
The square tubing sides are the later style. Changed to that in early 1983 I believe. Was Cooks where you checked? They had some too piled up in the 8000 section last it checked of the straight flat iron style. Not sure of what sides they were though. I'm going to be going down that way tomorrow and can look for you.
wekracer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wekracer Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2021 at 2:44pm
I’ve got a set that I took off that I would probably part with.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2021 at 3:41pm
Daehler, we called Cook's in Ill and Mo. Both said they had none. If your going that way you can have a look and let me know. I'd appreciate it.
Leon B MO
Edited by Leon B MO - 27 Aug 2021 at 3:45pm
