Calling all electricians
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Topic: Calling all electricians
    Posted: 21 Aug 2021 at 7:47pm
Stumped, wiring in a garbage disposal. Previous owner removed it. The wall switch is there but no wiring.
Was going to tap into the outlet for the dishwasher, installed new outlet, removed the tab on the hot side between the two outlets. Ran wiring up to the old switch, taped in to hot wire, connected switch, back down to the outlet, connecting to the screw on the other side of the removed tab. Turned breaker back on, flipped switch to test disposal, and nothing.
Plugged a floor lamp into the plug for dishwasher, and light turns on. Flip switch for disposal, plug lamp into that and nothing.
Got my multi tester, at switch, nothing when connect hot to ground.
Use multi tester in outlet for dishwasher, and sparks fly, plug in lamp and lamp works fine.
I unhook outlet, put black test probe on common wire, and red probe on hot wire and sparks fly
Where did I go wrong. I left the tab intact on the common side of the outlet.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2021 at 7:50pm
Black to Brass, White to Chrome, simple rule.  Are you trying to connect the hot to the N Side?
easiest to run a Romex wire pair from the Brass screw with a White under the feeder black then connect that to the input side of switch, connect the Black in that Romex to output of switch then down to the other brass screw.
Edited by DMiller - 21 Aug 2021 at 7:52pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2021 at 7:54pm
White on silver terminals, black wire on the brass terminals.
What is weird is a lamp plugged to the outlet and turned will work, put test probes in outlet and sparks fly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2021 at 8:26pm
you removed the terminal between the two BRASS SCREWS.. both sides are HOT, or connected to BLACK WIRE....
What you need is a series circuit... BLACK wire off he BRASS SCREW... run to the switch one side.. other side of switch to disposal INLET ... outlet wire of disposal back to the plug and connect to the WHITE side ( silver serews).
Edited by steve(ill) - 21 Aug 2021 at 8:31pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2021 at 9:02pm
Really you need to run a separate feed to the garbarator unit. They draw close to 12 amps.bet maybe a tad more,especially when 'stalled'.....
dishwasher will draw that  as well with heater on ,maybe 14
so both units on...BAM... breaker WILL blow.
Up here code says they have to be separate feeds
when I redid my kitchen ,it used up 21 of the 24 circuits in the pony panel...never ever had a breaker blow in 20 years...
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2021 at 9:02pm
Lars, i reread your post and i think you are trying to make the BOTTOM of the OUTLET hot ( washer) and the TOP of the OUTLET SWITCHED for the disposal... You would need to come off the HOT WIRE ( black / washer side) and run to the switch, then back to the  upper side of the OUTLET that you want to turn ON- OFF( this might be your WHITE WIRE - shown in red).... and yes, your TAB between the two  BRASS side of the outlet would be removed.. Then you plug your disposal into the TOP of the OUTLET and it should be switched on and off... If your light works, it should be OK. ..... If it looks like this and the disposal dont work, then it may be broke.
like JAY said, dont use both appliances at the same time.
Edited by steve(ill) - 21 Aug 2021 at 9:06pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2021 at 9:14pm
I did as Steve’s 2nd diagram. I agree with Jay on the separate circuits. Unfortunately currently the fridge, gas stove, and dishwasher on this same circuit. I will pull the panel cover tomorrow, and check to see if there is some piggy-backing of breakers. There a are a few empty spaces(breakers removed leaving a hole) on the panel.
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2021 at 9:39pm
Disposal is a very intermittent load. A 20 amp breaker will hold over 30 for several seconds at least, it doesn’t just trip at 20.1.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2021 at 8:18pm
Update: replaced the switch with new one, and everything’s working as desired.
Checked breaker box, no piggy-backs, at least not in the breaker box, further down line I don’t know about.
House is on pier-and-beam, so this winter will be good time to drop a dedicated refrigerator line down over then up to the breaker box.
