No Quality control
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Topic: No Quality control
    Posted: 21 Aug 2021 at 4:51pm
Helped a neighbor put a pressure tank in today. He got it from the local farm store. It was a bladderless tank and it is down in his well pit. Got it all hooked up and turned on the water and the brand new tank leaked where one of the fittings was welded in. Sure would be nice if they could pressure test before we went thru all the work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2021 at 9:23pm
Kinda like a water heater that we put into my parents house awhile ago. We got it at Lowes with a lifetime guarantee. When we went back to Lowes with it after it started leaking, about 7 years later, we were told that if it was leaking, it's lifetime was up.  Yep right the in the FINE PRINT it said when it quit functioning properly, for any reason, the waterheaters LIFETIME was over any the guarantee no longer applied.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2021 at 9:31pm
Dan, tell him to spend and extra dollar and get the tank with the bladder... Money well spent... Your "trapped air" will disappear over time into the water and the pump will cycle much more often... eventually burn up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2021 at 7:53am
I have not installed a Bladderless tank for forty years, as noted the air entrains into the water and end up recharging them all too often or cooking pumps on short cycling.  They also rust thru terribly quick with the recycled steels they use these day unless go full stainless then are back to Bladder tank expense level.
