WD 45 Carburator
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Topic: WD 45 Carburator
    Posted: 20 Aug 2021 at 5:34pm
I cleaned the carb and now need to know where to set the main jet and idle jet.
acd17toy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acd17toy Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2021 at 6:10pm
  Start with the needle jets about one and one half turns out , start engine and adjust to
 to smooth running after engine temp is up to normal operating  temp.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2021 at 10:49am
Ted,
Assuming this is a Marvel TSX464 Carburetor, I usually go 1 1/2 turns out from stop on the air/fuel and 1 turn out on the enrichment needle for a starting point. All engines are different and are going to need adjustments accordingly.  HTH
Steve@B&B
