ID
D19allisowner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D19allisowner Quote  Post ReplyReply Direct Link To This Post Topic: ID
    Posted: 15 Aug 2021 at 10:21am
Anyone know what engine this is. I was told it could possibly be a Kohler. All I know is it's pretty old.
Edited by D19allisowner - 15 Aug 2021 at 10:23am
If you choose not to decide you still have made a choice.
thendrix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote thendrix Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2021 at 10:31am
Not sure but if you try searching the casting number right above the flywheel it might get you started
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2021 at 12:52pm
My vote is Tecumseh
Tin shrouding is all gone so will run hot until cooks.
Basing on gas tank and flywheel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2021 at 1:19pm
cylinder bolts to the crank case block... That is not common on most... Should tell you something.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2021 at 6:16pm
its a wisconson probley ah model
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2021 at 6:19pm
lets see the rest of the tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2021 at 6:30pm
Ditto!  Sometimes if you ID the machine, you can figger out what motor it is!Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote D19allisowner Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2021 at 4:22am
It's a home built machine that friend of mine has so seeing the rest of it's not going to do you any good.
Tad Wicks View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tad Wicks Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2021 at 10:01am
It is a Wisconsin, the air cooling shroud is gone and that is where the data plate is. Almost indestructible, as proven this has been run with no cooling, they can take almost anything but no oil.
Edited by Tad Wicks - 16 Aug 2021 at 10:13am
