food saver
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Topic: food saver
    Posted: 13 Aug 2021 at 2:32am
i gotta get a new one, the last one...well i guess i musta wore it out! spent almost 45 mins today trying to seal sweet corn for the freezer. it would suck it down good, but won't put a good seal on the bag. PfffffT! it sure has worked fine up til now.
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2021 at 5:50am
Might try different bags?
I bought a cheap roll and they didn’t work well.
Heating element may have went bad.
Last year we tried leaving the corn on the cob. Worked well.
Mnfarmboy View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mnfarmboy Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2021 at 11:40am
Try replacing the black oblong foam rubber seals, there are two of them.  My food saver would'nt pull a vacuum either,  the new seals fixed that.  You can get new seals from Amazon they were not that expensive.
Dave
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mnfarmboy Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2021 at 11:43am
Oops, should have read the posting and paid attention to what you were saying that did not work.
Dave
fixer1958 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fixer1958 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2021 at 8:03pm
Been using one for a long time. Foodsaver brand mostly. It can be aggravating as hell sometimes. Moisture can be a problem on the sealing edge as in none there. Sweet corn has a lot. I just did some and had to put it the freezer bagged ready to seal for a couple of hours. Fine after that. If you question the seal do it again. Insurance.
Foodsaver bags are heavy duty. Makes for a problem sealing sometimes. They have others out there that work good too and not as pricey. I won't buy foodsaver bags because of the price and try to hit a happy medium on what I get and they work fine.
I did some corn that was dated years a few months ago and it was as good as what I just put in the freezer.
Boney meat will puncture a bag on vacuum. That's when I use the HD bags.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2021 at 10:01pm
What fixer says about partially freezing before trying to seal. My bride was trying to seal some butter beans and the bags wouldn't seal. I told her to put the beans in a pan in the freezer for about 15 minutes, then bag and seal them. Worked good. Now she thinks I am smart. Ground venison seals better when it is chilled and then bagged also.
This page was generated in 0.184 seconds.
