identifying gleanor motor on d 17
rlgraves View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rlgraves Quote  Post ReplyReply Direct Link To This Post Topic: identifying gleanor motor on d 17
    Posted: 14 Sep 2010 at 1:20pm
How can one identify which gleanor motor is on my d 17 bought used to pull. has place for mechanical fuel pump and a number 2 on the right side of the block any info would help thanks
LannyMTN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LannyMTN Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2010 at 2:46pm
Look at the engine serial number on the block behind the carburetor, and post back with the letter at the end of the number. Should be D17-XXXXX-?. Someone will tell you the compression ratio based on the letter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rlgraves Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2010 at 2:52pm
thanks will look and see but dont recall there being a number there.
