In Auger ation part 5 - the end |
Creek Jenkins
Joined: 14 Sep 2009 Location: Northern Minn Points: 812 |
Topic: In Auger ation part 5 - the endPosted: 14 Sep 2010 at 12:54pm |
12" auger on a Ottowa Farm Chief 3 pt setup I picked up at auction.
While drilling holes, the gearbox gave up on the 5th hole. Cracked the pinion bearing mount.
Thanks to R. Aiken, I got another gearbox and put it all back together last weekend. Everything looked good, I used a grade#2 1/4" bolt for a shear pin. Drilled one hole about 2 feet deep and sheared the bolt when I hit a rock. Okay, I can live with that as long as the auger holds together. I'm running it with the engine just above idle to keep it as slow as possible. 1/4 bolts are cheep.
Set it up the other day to drill holes for scratching posts for the animules, got down about 2 feet, hit a rock and the dang cross on the gearbox u joint popped out and the cap went zinging off. I'm expecting NASA to call me when it reenters the atmosphere. Shear bolt is fine.
So I'm done. I think the 12" diameter is just too big for this clay and rocky soil here. Either that or the dang thing is haunted by an evil spirit or cursed by some kinda voodoo. I'm going to fix it and sell it to someone that lives in sand country and buy me a newer unit with an 8 or 9" auger. Hopefully the new owner won't have to call for an exorcism.
Thanks for listening!
Cheers,
Creek
R Aiken
Posted: 14 Sep 2010 at 2:25pm |
Go ahead and use the 12" augur. I have two more gearboxs. You had me worryed for a while. Richard
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42271 |
Posted: 14 Sep 2010 at 3:07pm |
Get out the chalk, mark the auger up the flute , add cutting torch to chalk line .. One smaller auger : result of work
Creek Jenkins
Posted: 15 Sep 2010 at 9:24am |
Richard - thanks for your support! But the dang thing has kicked my axe one time too many. If I lived in an area without so dang many rocks prob would never have this problem. Maybe I'll take Coke's advice and just cut it down. Or better yet sell the 12" bit and buy a 9" instead. The bit is like new, should be able to get a few bucks for it. Hmmmmmmm........
Cheers
Creek
Dave Richards (WV)
Joined: 14 Sep 2009 Location: Fairmont, WV Points: 881 |
Posted: 15 Sep 2010 at 10:18am |
Creek, how about using a 9" auger for a pilot hole and use the 12" to ream it out?
Creek Jenkins
Posted: 15 Sep 2010 at 1:11pm |
Dave not a bad idea, I'm just tired of putting munny in this thing and ready to start over again. But getting a different whole digger assembly doesn't mean I won't have the same prob with the rocks. Prob should just kool off for a month or two and then decide. Buying a 9" auger wouldn't kost that much and I if I bought a whole new assembly I would need an auger anyway.
Might try that.
cheers,
Creek
R Aiken
Posted: 15 Sep 2010 at 2:02pm |
I have the 9" augur that was on the gearbox you have. Richard
Creek Jenkins
Posted: 15 Sep 2010 at 2:38pm |
What the helms shoot me a price I might just give it a try. If you have a pic maybe as well? Shipping would prob kill me though...... cheers, Creek |
