Battery cables
1947WC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1947WC Quote  Post ReplyReply Direct Link To This Post Topic: Battery cables
    Posted: 08 Aug 2021 at 2:37pm
Does any one know if 8guage cables are heavy enough on a 12 volt conversion.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2021 at 3:16pm
NO... not for the starter... You need at least 4 gauge...2 would be advised.. smaller numbers are BETTER.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2021 at 3:23pm
No at least 4 only if it's short.2 would be better O if it's a long run.i get mine made at the local JD they make to the exact length and hyd pressed ends.
Edited by Dakota Dave - 08 Aug 2021 at 3:25pm
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2021 at 8:50pm
I always go for thicker cables than what is called for.  Might be overkill, but I know they shouldn't cause any problems for a long time.  I just replaced the original 4 gauge cables with 0 gauge on my 1960 D14.
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2021 at 12:19pm
I make most of my replacement battery cables.
NAPA has terminals which can be soldered.
Welding cable works great.
Remove only enough insulation to reach bottom of the conductor hole in the terminal.
Tin the bare cable.
Insert  cable into the conductor hole in the terminal.
Coat the bare wire with solder paste.
Heat the cable with a HOT soldering copper and add melted rosin core solder .
Allow to cool before moving the wire.
ac hunter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac hunter Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2021 at 2:38pm
     I like to put a piece of shrink tube over the end of the cable covering as much of the clamp as possible. Got some heavy shrink tube from NAPA some years ago that has some sort of sealer that melts and seals the ends really well. Amen about the heavy cable.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1947WC Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2021 at 5:09pm
Thanks  to  all  who helped me  on the battery cables.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2021 at 7:03am
We have Battery cables in stock. I also make cables to the customer's C to C measurements. As the guys mentioned, 4 ga. is the norm for 12V systems. Using a 1 gauge cable (the norm for 6v) would be plenty heavy enough on a 12V system....
Steve@B&B
This page was generated in 0.836 seconds.
