D-17 XT turbo diesel for SALE !! |
Post Reply |
DrAllis
Orange Level Access Joined: 12 Sep 2009 Points: 20935 |
Thanks(1)
Posted: 08 Aug 2021 at 7:46am |
AUCTION IS CLOSED FINAL BID OF $6,750.00 ..... THANKS TO ALL BIDDERS. GOING TO CENTRAL MISSOURI.
Edited by DrAllis - 12 Sep 2021 at 6:23pm |
DougG
Orange Level Joined: 20 Sep 2009 Location: Mo Points: 8180 |
I know some people dont like Facebook- but - it would be good to advertise this on Facebook Marketplace !!! Theres 2 - no disrespect meant here- but younger generations that go $$$$$$$ crazy on Allis Chalmers items are on there - and this is a great item
DrAllis
I think my Nephew is going to do that. Thanks. Current top bid is $5500. Bidding coming from area codes 573 and 402 and inquiry from 256. Thanks for your interest and bidding.
DrAllis
Bid is now $6,000 from 573 area code. Thank you.
SteveM C/IL
Orange Level Access Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8353 |
Buckle yer belt! It will be like a rocket ship near the end!
Charlie175
Orange Level Joined: 11 Sep 2009 Location: Shenandoah, VA Points: 6358 |
It's on Facebook also
Good luck!
Charlie
'48 B, '51 CA, '56 WD45 '61 D17, '63 D12, '65 D10 , '68 One-Ninety XTD |
coggonobrien
Orange Level Access Joined: 14 Nov 2010 Location: Eastern Iowa Points: 1843 |
It's posted to the allis chalmers facebook pages and the d17 page.
coggonobrien
DrAllis
New bidder from 256 area code of $6500 dollars. Thank you.
** Just a reminder, the last bid will be taken on Sunday September 12th at 6PM Central time.
Edited by DrAllis - 10 Aug 2021 at 8:56pm |
coggonobrien
Allis dave
Orange Level Joined: 10 May 2012 Location: Northern IN Points: 2938 |
That's a great looking and modernized tractor. Worth every penny.
DrAllis
These are the rear tires intended to go with the tractor. Wheel centers and hardware are going to the paint booth this weekend. Good-Year 16.9 x 28 Dyna-Torque II that are 80%+ tread. They aren't new, but the tread is very good. Rims are good. The tractor ride tires are available as well as an accessory. Current bid is $6,500. Last bid to be taken is by 6 PM Sept 12th.
Edited by DrAllis - 19 Aug 2021 at 7:07am |
nickia
Orange Level Joined: 11 Sep 2009 Location: alden iowa Points: 790 |
please explain your hydraulic system on your series 3
coggonobrien
Original high pressure system is intact and fully functional. The 433t has a 190 pump installed to it for high flow low pressure. |
DrAllis
It has a hydraulic valve/console from a 170-185 to the right of the seat. Live hydraulic power comes from the engine mounted (under the alternator) hydraulic pump from a 190/190XT. This triple section pump provides oil for the hydrostatic power steering and all the hydraulic lift/lower functions to the levers to the right of the seat. The lift arms have two external lift assist cylinders that work together (all three) with the internal lift cylinder for the hitch. With the lower hydraulic system pressure (2,200 psi) it takes more cubic inches of cylinders to lift the same load that the one internal cylinder used to do at 3,700 psi. The internal high-pressure system is still intact and functional with the two levers on the steering column and work just like they always did. So, there is a 3,700 psi one-way system and a modern 2,200 psi two-way live system all on one tractor. The 3-point hitch can be easily dropped off in 15 minutes or less to be able to still use snap-coupler implements.
Dlesh
Bronze Level Joined: 01 Aug 2021 Location: Fountain Points: 8 |
With the snap coupler arms, is that then an after market three point hitch? Great looking tractor.
DrAllis
The entire 3-point hitch and drawbar are fabricated by myself, except for the lower draft arms, which are from a 190XT, and are the same as a D-17 series 4. I hate lower draft arms that don't have the "extendable" feature to help aid in hooking up to implements. A new tractor today of this size wouldn't have that feature. The top link anchor bracket also has 4 holes in it to tweak the angle of the implement. Most add-on hitches only have one hole. Draft arm width can be set for Cat #1 or #2. Going to try and get the 16.9 x 28's and freshly painted wheel centers installed this weekend for final pictures to be taken. Top bid right now is $6,500 from 256 area code. Bidding ends on Sunday Sept 12th at 6 PM central time. Call or text 319-360-4788 to place your bid. Thanks.
**** Tractor available to ride and drive by appointment.
Edited by DrAllis - 26 Aug 2021 at 5:54am |
Alberto S
Bronze Level Joined: 26 Aug 2021 Location: Toronto, Canada Points: 3 |
Good.
DrAllis
I've been working on printing up an Operators Manual for this particular tractor, and thought some might be interested in the MPH speed in each gear at 2300 engine RPM's with the 16.9 x 28 rear tires: 1st- 2.6.....2nd- 3.7..... 3rd- 4.2.....4th- 5.6.....5th- 5.9.....6th- 7.8.....7th- 12.0.....8th- 17.1..... and 8th high idle of 2500 RPM is 18.6 MPH.
coggonobrien
If you need help saving the manual as a pdf to email out let me know
coggonobrien
Final pictures in selling configuration. Video to follow
DrAllis
Two weeks from today is the end of bidding, at 6PM Central time. Current bid is $6500 from area code 256. Front tires are brand new. Rear tires are 80% or better. A very nice and pretty modern turbo-diesel working tractor.
coggonobrien
DrAllis
Got a text an hour or so ago asking how soon the tractor needs to be picked up if he were the new owner. My response was, if needed, I could probably store it all Winter. So, I extend that offer to any others who may have some distance to have to transport the tractor home. I would expect you to have insurance on it while in my shed. Tractor needs to be paid for within 7 days of the auction close time. Thank you.
SteveM C/IL
Lol....Doc looks like he hangs his extra eyes on his shirt collar too....
DrAllis
Bid from 573 area code is now at $6750.00. Thank you.
SteveM C/IL
I predict +$4000 minimum over that....
DrAllis
FINAL BID OF $6,750. GOING TO CENTRAL MISSOURI.
SteveM C/IL
Wow! I was wrong. That was a great deal for the buyer!
IBWD MIke
Orange Level Joined: 08 Apr 2012 Location: Newton Ia. Points: 3841 |
Somebody got a heck of a tractor for a bargain price!
Post Reply | |
