CA hard time starting
mosstrumpet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mosstrumpet Quote  Post ReplyReply Direct Link To This Post Topic: CA hard time starting
    Posted: 07 Aug 2021 at 3:36pm
I recently Bought a 1951 CA.
Engine was hydrolocked but was able to free it up and have good compression in all cylinders. I rebuilt the carb, used Steiner Kit - Came apart and went together smoothly. Got it fired up and ran poorly. After some investigating, found the Governor was out of whack and adjusted the arm to 1/16" to short to throttle linkage. This definitely helped the pulsing but also flooded the hell out of it as I was running it with to much choke, but was necessary when the governor wasn't set right.  So needless to say fouled out the plugs, once they were cleaned up I wasn't getting any spark from the distributor. I pulled the distributor, Marked everything for reassembly, gapped and polished the points and contacts in cap, checked the coil and everything was good. I cleaned up the ground on the coil and got spark back.
I have Fuel, I have Spark but I am having a hell of a time starting it now. Choke is adjusted properly. It acts like it wants to start but then putters out and after a few tries I have to hook the battery up to the charger. Fuel is turned on at the sediment bowl so that not it.
Any thoughts would be greatly appreciated.
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2021 at 4:35pm
Check timing and spark plug firing order
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2021 at 8:47pm
Check that the carb is not letting too much gas into the engine.  The needle and seat in my carb would stick open and flood the engine with gas.  Hard to start after that because it had to clear all the gas out of the cylinders.
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2021 at 8:48pm
The battery sounds questionable. I would start there and verify all battery cables are good and clean with a known good battery.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2021 at 9:53pm
I'm with Ted, timing.                MACK
