D-17 Power Steering - Adding Fluid |
Post Reply ![]() |
Brian G. NY ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: 12194 Points: 2244 |
![]() ![]() ![]() ![]() ![]() Posted: 14 Sep 2010 at 9:10am |
When I first got my D-17 (series II) I checked and topped off all fluids. It seems odd to me how the fluid is checked and filled in the power steering. I pulled the distributer and brought the fluid up to within 1-5/8" of the top of the distributer opening as directed in the repair manual. The operator's manual is a little vague on this. When I had to work on my distributer recently, I noticed the fluid level was down so I put in some more to bring it back up to the recommended level. It took maybe a third of a cup. I know for a fact that a neighbor farmer has always removed the vent cap at the front bolster behind the grill to add fluid to his D-17 which apparently leaks a bit. How do all of you other D-17 owners maintain fluid levels in you P.S. systems? |
Ryan Renko ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Edwardsville, I Points: 2325 |
Behind the front grill screen on my IV.
D-17_Dave ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Mocksville NC Points: 990 |
The PS resorviors on the D-series are filled in front of the radiators. The front bolster houses the steering mechanism and is used as the reservior.
Matt MN ![]() Orange Level ![]() ![]() Joined: 14 Sep 2009 Location: Silver lake MN Points: 1491 |
Behind the grille screen
Clay ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Udall, Kansas Points: 9504 |
Brian, The fill port on a D-17 is located behind the grill, in front of the radiator.
Clean all dirt away from the area before opening. There is a breather looks like a small cylinder with a nut on the bottom. Remove this and check the fluid level. The front support is the power steering oil sump. Keep filled to 5/8" above top of segment gear. No need to remove the distributor. |
OK, I get it now! I went back to my operator's manual and read just what Clay said.
When I re-read the part about the "Distributer Drive Housing," I see what they mean;
for those tractors with power steering the dist. drive housing should contain fluid within 1-5/8" from top of housing. Manual says check every 300 hours of operation. It appears that the oil in here may be leaking out and I wonder if this is the cause of the wear on my distributer gear?
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 20978 |
Yup.....just pack the cavity with gun grease instead.
Post Reply ![]() |
