Ignition
CoreyI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CoreyI Quote  Post ReplyReply Direct Link To This Post Topic: Ignition
    Posted: 03 Aug 2021 at 9:01am
Hello everyone. I’m looking to convert my WD45 to electronic ignition. I plan on using the PerTronix kit and flame thrower coil. I am also switching the plug wires to graphite. Question is, do I have to run an external resistor with this coil and do I need to run different plugs ?
Thanks
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2021 at 9:24am
No for both questions
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2021 at 10:06am
Just be sure to get a coil for a 4 cylinder and the voltage of your tractor's system.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CoreyI Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2021 at 1:36pm
Thanks guys
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2021 at 1:51pm
We can help you out with all that you're lookin' for. Visit our website. I build the spark plug wire sets for each cylinder.  You don't need to use the Blaster coil although its a nice enhancement. Totally optional. If your 45' is still on the OEM 6VPG system, the stock coil will work fine.  If you flipped it to 12V's, you'll need to hook yourself up with a 12V/3.0 Ohm coil that's internally resisted. We have them in stock also. Definitely don't want to use a ballast resistor. They didn't work under the hoods of 60's Automobiles, never mind out in the elements on a Tractor.  An internal resisted coil (12V's) keeps Mother Nature out so the Tractor runs nice.
Steve@B&B
bb-customcircuits.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote CoreyI Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2021 at 7:58pm
Will do. Thanks
This page was generated in 0.367 seconds.
