Freeman 2 inch cyl seals |
| Author | |||
CraiginMO
Joined: 13 Sep 2009 Location: Rockford, IL Points: 43 |
Topic: Freeman 2 inch cyl sealsPosted: 01 Aug 2021 at 9:48am |
Got my new to me Freeman model 90 loader home yesterday. She bolts right up. The hyd cyl are 2" and I have only found seal kits for the smaller cyl. Anyone have part #'s for the 2" cyl? I will have to fabricate the rear brackets. The ones that came with it are for a WD45.
![]() Edited by CraiginMO - 01 Aug 2021 at 9:52am |
| Sponsored Links | |||
JTOOL
Silver Level Access
Posted: 01 Aug 2021 at 11:32am |
The rods are 2"?
Gary
Joined: 13 Sep 2009 Location: Peterborough,On Points: 5911 |
Posted: 01 Aug 2021 at 12:26pm |
That loader side frame in your picture is not from a Model 90. Model 90 is for a WD or WD-45 and are tubular. What you have appears to be the correct side frame for a D-14, and would be a Model 140. Gary |
CraiginMO
Posted: 01 Aug 2021 at 1:33pm |
Hmmm, the data plate says otherwise. The WD90 was a tube frame but this is just a model 90. ![]()
Edited by CraiginMO - 01 Aug 2021 at 1:52pm |
CraiginMO
Posted: 01 Aug 2021 at 1:34pm |
Yes the pistons are 2"
Gatz in NE
Joined: 11 Sep 2009 Location: Lincoln, NE Points: 1064 |
Posted: 01 Aug 2021 at 2:06pm |
Craig, I have mounting brackets that might work for your loader. However, they came from a Freeman loader mounted to a D17. What size is the lower horizontal rectangular tube ? |
CraiginMO
Posted: 01 Aug 2021 at 4:25pm |
These are 5.5x2.5 inches
Gary
Posted: 01 Aug 2021 at 6:17pm |
That loader boom would originally been part of a complete loader package meant to be installed on a WD or WD-45. Thus the ID of Model 90. It's predecessor was the Model 9. There was no loader identified as WD90. CA's had a Model 9, D-14 had Model 14, then Model 140. D-15 Model 15, then 150. Gary BTW WD, D-15, and D-17 used the same Boom. |
Gatz in NE
Posted: 01 Aug 2021 at 6:21pm |
hmmm, that's odd The brackets that came off the D17 have a 2 3/4 x 5 1/4 opening which would be ample clearance for 2 1/2 x 5" tubing. Are you sure about the 5.5 dimension? 2 1/2 x 5 1/2 is kinda odd size tubing too.
Edited by Gatz in NE - 01 Aug 2021 at 6:24pm |
Gary
Posted: 01 Aug 2021 at 6:29pm |
Original Factory Allis Loader Manuals on Ebay: CA Model 8 and WD Model 9 https://www.ebay.com/itm/154451694028?hash=item23f609d1cc:g:FSQAAOSwXwhgnUC0 D-14 Model 14, and D-17 Model 17 https://www.ebay.com/itm/393171069883?hash=item5b8ad26bbb:g:hv4AAOSwdRdgQCRe G |
CraiginMO
Posted: 01 Aug 2021 at 8:52pm |
I checked again. Those are correct. No problem I think there are 2 mounting hole in the axle under the fender that are free to use.
CraiginMO
Posted: 02 Aug 2021 at 8:35am |
Ok I was a little off. I was measuring the bracket opening and not the tube. The tube is 2.5 x 5.25.
john(MI)
Posted: 02 Aug 2021 at 12:17pm |
On my D14 the rear mounting bracket goes on two mounts cast on the read of the axle. They are bent at the mounting end at 90*, probably a little over an inch. there are two bolt holes on either side. Since those holes are vertical, it took me quite a while getting the dirt out of them. My loader has a round tube frame, but I would suspect yours would mount the same way. From your picture I see you have a more pressing issue than mounting the loader!
CraiginMO
Posted: 03 Aug 2021 at 7:47pm |
Yup same holes here. That is what I will use. The head was original. Once off it was obvious it needed a complete valve job. $500 later and I am ready to reinstall
CraiginMO
Posted: 17 Sep 2021 at 5:12pm |
SO I finally ID my 2 inch piston cylinders with my local dealers help. The loader is a model 90 but the cylinders are from a model 170. AGCO cannot help with seals but I found them online at Sealsales.com If you need them they are as all sold EACH. so you need 2x VR2000X2500FF females, 2x VR2000X2500MF males and 6x VR2000X2500VF packings to do both cylinders
Gleaner E, D17, WD, D-14
Mikez
Posted: 18 Sep 2021 at 8:12am |
think we have some nos packings
Alex09(WI)
Joined: 15 Mar 2012 Location: CECIL WI Points: 1779 |
Posted: 18 Sep 2021 at 12:03pm |
part # should be 2000501/2000502 --> 2000652
www.awtractor.com
A&W TRACTOR 920-598-1287 KEEPING ALLIS-CHALMERS IN THE FIELDS THROUGH THE 21ST CENTURY |
