hyd pump
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Topic: hyd pump
    Posted: 29 Jul 2021 at 9:40pm
where on a 190XT is the pump that runs the hyd's? the steering works, the 3-pt works, but it won't raise a disk or plow on the hyd cylinder. i don't want to replace the wrong one.
youngorange2000 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote youngorange2000 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2021 at 10:26pm
It's all one cam driven pump with flow divider valve. It's on the front driver's side of engine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2021 at 6:17am
Sounds like you may have a relief problem. There is two on valve stack below the levers. Switch places with them.                 MACK
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2021 at 9:30am
The earlier 190's used a triple section pump without a flow divider.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2021 at 9:41am
The original triple section pump had a flow-divider/priority valve located vertically on the back of the pump to see to it the power steering and Power Director/PTO circuits always received 4 to 5 GPM's at all engine speeds and the excess flow was recirculated back into that sections inlet.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2021 at 2:05am
thanks!
