6060 No Hydraulics
shamrock View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shamrock Quote  Post ReplyReply Direct Link To This Post Topic: 6060 No Hydraulics
    Posted: 28 Jul 2021 at 9:48am
Have a new to me 6060, mowed with it yesterday. Want to bale with it today. No hydraulics, no steering, no 3point no lift cylinders. Hydraulic fluid level is good. Kinda puzzled, went from working fine to nothing. Any suggestions on where to start before i start tearing into it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote shamrock Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2021 at 11:32am
Update. I took the hydraulic pump off, the engine side seems ok and turns when the engine is running. The pump shaft turns and appears to have suction when the shaft is turned. i filled the pump with fluid, as best as i could, put er' back together and still no hydraulics.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2021 at 4:36pm
Check your suction line , have found so much junk in them at the filter and screen
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2021 at 8:46pm
Put new font seal in pump, fill pump the best you can with heavy oil, along with suction line. Start engine at 2/3 wide open.
Make sure hydraulic is full of oil.                   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2021 at 7:15am
Does it have the pump connected to suction on bottom with hose to tube? My 220 would loose prime after setting. That hose had a leak letting air in but no oil out and oil would drain away. Head scratcher for awhile.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shamrock Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2021 at 8:01am
Thanks guys, suction strainer was plugged, unreal how much crap was in it. I had changed all the filters on her when I bought her, didn't know about the screen in the sump.
Filled the pump like Mack instructed, new filter and hy-tran and she's working like a champ.
