H3 steering/brakes
elec View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote elec Quote  Post ReplyReply Direct Link To This Post Topic: H3 steering/brakes
    Posted: 26 Jul 2021 at 8:51pm
Just got an H3 at an auction on Saturday. Just curious, do the steering clutches activate the brakes or do you have to use the pedals?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2021 at 9:28pm
Brakes and steering clutches are separately applied - clutch first then the brake is used to turn . HD 4 is the same - later units use pedal steer to apply clutch first and then brake .
ZachD89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ZachD89 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2021 at 9:31pm
The brake pedals help steer. The long lever just releases the clutch. To turn you have to use both.
37 A,37 Waukesha B,35 WC,38 WF,M crawler,49 WF,49 WD,53 WD45,39 and 40 RC,47 WC,41 B,39 B,48G,48,C,59D10,D21,IB,B10,B12,B208,B1,Roto Bale Loader, sp100 combine, allcrop 66, L3 Gleaner
elec View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote elec Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2021 at 10:16pm
Ok thank you
This page was generated in 0.210 seconds.
