Best brand of oil filters |
Darwin W. Kurtz
Joined: 06 Apr 2010 Location: Westphalia, KS Points: 5698 |
Topic: Best brand of oil filtersPosted: 20 Jul 2021 at 11:24pm |
wondering which kind you think is best
I tend to use mostly Wix, (Wix is locally available with a great dealer) some Baldwin or Hastings, & Motorcrafts (Motorcraft for our Ford) |
HD6GTOM
Posted: 20 Jul 2021 at 11:51pm |
I put on hundreds of oil filters while we had our business. NAPA gold were heavier than all other brands. The only problem we ever saw, the dang gaskets stick to the block.
Ed (Ont)
Joined: 08 Nov 2009 Location: New Lowell, Ont Points: 1606 |
Posted: 21 Jul 2021 at 6:03am |
Wix is certainly one of the better ones. Napa gold is made by wix.
Lars(wi)
Joined: 14 Sep 2009 Location: Permian Basin Points: 8405 |
Posted: 21 Jul 2021 at 6:35am |
The only vehicle I routinely change myself is our class A motorhome. Most of the time I get the Motorcraft, or a Wix.
At work, 95% of the filters on the trucks, and frac equipment have Baldwin, with a few Donaldson thrown in. |
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 90878 |
Posted: 21 Jul 2021 at 8:36am |
Filters is like arguing about oil or trucks... All the BRAND NAMES are comparable. A lot depends on what your local supplier sells or where you shop.
I do buy FORD filters for our vehicles. Had troubles 20 years ago with one ticking on startup.. The FORD had anti drain back valve in it.. Fixed the TICK.. Never changed back to anything else.
Boss Man
Joined: 03 Mar 2018 Location: Greenleaf, WI Points: 617 |
Posted: 21 Jul 2021 at 1:19pm |
Wix, Baldwin, Hastings are the top manufactures. Wix markets under a lot of different names. So does Fram. Non of them make all their own filters. They source certain types from others. Baldwin supplies alot of of hydraulic filters to other manufactures.
john(MI)
Posted: 21 Jul 2021 at 5:32pm |
I have been using Fram for years and have not had any troubles. I even got a bunch for my AC's.
FREEDGUY
Joined: 15 Apr 2017 Location: South West Mich Points: 5396 |
Posted: 22 Jul 2021 at 8:27pm |
Believe it or not, I get a GENUINE MOTORCRAFT 820S filter at my local Walmart or the Rural King for $ 3.97
klinemar
Joined: 14 Sep 2009 Location: Michigan Points: 8074 |
Posted: 22 Jul 2021 at 9:56pm |
For my farm equipment I use either Wix or Baldwin whichever my supplier has in stocks. For our car and truck I take them to a local Mechanic Garage to change oil. Too low for me to crawl under!
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35704 |
Posted: 23 Jul 2021 at 4:54am |
Worked as a mechanic some 20+ years, would not install a FRAM on a bet. Would cut filters open as a engine failure occurred where a great deal of FRAM or other Cheap filters failed the inspections.
I use Baldwin, WIX, Motorcraft(Ford Sold) and CAT branded filters, for heavier later machines FLEETGUARD is another. Used AC(GM Line) for a long time but unable to get them locally anymore and Goodwrench seems to be the replacement name. Edited by DMiller - 23 Jul 2021 at 4:57am |
modirt
Joined: 18 Jul 2018 Location: Missouri Points: 9463 |
Posted: 23 Jul 2021 at 9:41am |
Who makes AGCO filters?
Ray54
Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4875 |
Posted: 23 Jul 2021 at 11:04am |
The guy making them the cheapest.![]() |
