190XT Series 3 for sale needs work
youngorange2000 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote youngorange2000 Quote  Post ReplyReply Direct Link To This Post Topic: 190XT Series 3 for sale needs work
    Posted: 19 Jul 2021 at 10:27pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote youngorange2000 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2021 at 10:34pm
I had done a in frame engine rebuild 20-25 hours ago and had the injectors rebuilt and put a reman used head on. I was discing with it when I stopped to unroll a old hay bale. I idled down from 90 to 40 percent throttle while I was unrolling the bale I heard the hydraulic pump grind for about 3-5 seconds then the tractor shut down abruptly. The engine spins over super fast like no compression. My guess is hydraulic pump locked up and took out the cam or cam key. Otherwise all other mechanical things were working fine. I have the grill and tractor is complete except the rear lower hood panels and is a very straight tractor. I am asking $2500 for it. Or $200 if I keep the new turbo that's on it. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote youngorange2000 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2021 at 10:35pm
*$200 no turbo $2500 complete with turbo also have complete spare 3 point for it
Post Options Post Options   Thanks (0) Thanks(0)   Quote youngorange2000 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2021 at 10:36pm
$2000 no turbo
d17brown View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote d17brown Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2021 at 7:41am
Where are you located
phil
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2021 at 8:26am
Too bad it's so far!
Post Options Post Options   Thanks (0) Thanks(0)   Quote youngorange2000 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2021 at 8:39am
Central mn
