185 3 point won't lower while running
tnac View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tnac Quote  Post ReplyReply Direct Link To This Post Topic: 185 3 point won't lower while running
    Posted: 17 Jul 2021 at 4:14pm
I have a 185 that the 3 point will not lower while running. If off it will lower but raises immediately when started. Any suggestion?
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2021 at 5:10pm
You have a hydraulic spool stuck or linkage ( ussually draft control ) that is binding and letting the spool return to center. Soak all linkages with penetrant that are in under the plate connecting to all 4 or 5 levers. They must all move.
Try moving the 2 levers setting behind the 3 pt and remote cylinder controls. Move too far back and then forward a few times. Start tractor and see if it operates.
There's older posts on here from people that explained it a lot better.
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2021 at 5:11pm
Traction booster/position linkage is froze up most likely.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2021 at 5:57pm
Just fixed a One-Seventy today by loosening the pivot bolt the TBoost finger pivots on. Let the bolt be the pivot and quit worrying about the bushing inside of the finger.
This page was generated in 0.071 seconds.
