XT/200 ??
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Topic: XT/200 ??
    Posted: 16 Jul 2021 at 8:40pm
All things being equal- hours, paint, tire condition, which would you guys prefer ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2021 at 8:58pm
190 XT, as the 200,s seemed differt and  at mid point was a cost reduced in certain areas, the XT,S were always solid
Edited by DougG - 16 Jul 2021 at 8:59pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2021 at 9:10pm
If it’s a series IIIXT then it will have the same reared as the 200. A few changes on the 200, short throw PD, grill, fuel system. Either one is a winner in my book. I personally like the long throw PD on my XT verses the 200.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2021 at 9:29pm
All things being equal, they are both the same tractor!  Very minor changes between a series 3 and 200.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2021 at 9:50pm
200, heavier finals, housing and ring gear pinion.... pistons were different to prevent gaulding - (most have been changed by now)  20 % more cooling capacity and increased engine oil capacity. 200 hyd pump (same as late series III ) was much better.  The late 200 had a smoother shift in the pd via better shift valve. 200's had option of and most had 38" rear tires and larger front tire option.
LionelinKY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LionelinKY Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2021 at 10:25pm
After growing up with this girl over the last 50 years, I'll have to admit being just a little bit biased-LOL.
btred1466 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote btred1466 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2021 at 10:47pm
What are the differences in the 190XT and 200 Brake Systems?
What is involved in changing one of these from a Mechanical PTO to a Hydraulic PTO? If it possible, which I think it is, curious about this. Also a Single 540 PTO to a Dual 540/1000PTO?
I don't own either or any Allis Chalmers but I like both those Tractors 190XT and 200's.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2021 at 11:53pm
late brakes were expanding center with discs - like the 7000 .  Early were like the 190 band expanding drum.  See agcopartsbooks.com and compare.  It would require a donor tractor and a major job to convert to hyd pto and questionable upgrade unless starting and stopping the pto a bunch.  Single to dual pto requires rear lift hsg swap and guts. Rare options as it added a substantial amount to invoice.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2021 at 9:28am
A 200 is the most refined version of the 190XT. Many improvements. The 7000 is the final revision of that basic powertrain, but is significantly different, it's basically in a class by itself. A late XT would perform like a 200 in the field.
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2021 at 10:03am
One of the biggest improvement on the 200 was the crank driven oil pump and piston cooling.
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2021 at 10:10am
Anyone ever think about putting a 7000 drive train in a 200 ???
nonetheless ,still dead.
Ky.Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ky.Allis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2021 at 1:33pm
I'm not positive but didn't the 200 have nicer seat with fold up arm rests and above hood muffler and I know they had the option of tilt/telescope steering wheel cause mine has it. Late 200's with the gated PD control is super easy to shift/feather with the short throw and hand guide. The 200 was the last AC tractor made with manual shifted PD that you could "feather" during operation. Some talk about later 200"s being "price cutter" version. Well that's what mine is and only difference I ever saw was 2 headlights instead of 4 and the hollow front support. On the positive side that hollow front support allows you to change the front crank seal without removing the entire front end. So the "price cutter" myth does not amount nothing!!!!   With the 540/1000 hyd. PTO option;they were a pretty darn good tractor in their day.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2021 at 5:16pm
From what I've read, the 7000 is a "bastard child" ???
Post Options Post Options   Thanks (1) Thanks(1)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2021 at 5:55pm
I've often thought about taking a maroon 7000 and grafting 200 Sheetmetal onto it. The length of the torque tube is exactly the same. The length of the rear end is too. I'd use 200 side frames, front axle and radiator/hood/dashboard/cowl/clutch/brake pedals /platform/console control. It could be done and would be a sleeper to an untrained eye. True "independent" PTO and three-speed Power Shift with a real road gear !! whooo hoooo  !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2021 at 6:13pm
Thanks for the info, but that's  WAY too much work $$ for the average first time/ STO operator IMO Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2021 at 6:18pm
Simply a response the Fred's question. It would be a big project, almost requiring two whole tractors. The brake pedal linkage would be a challenge. The clutch pedal linkage would be as well. Other than that, I don't see anything else that would pose a serious engineering problem. It would be really cool and expensive to do. The 7000 torque tube requires use of a 7000 rear end and that would essentially be the entire driveline.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2021 at 6:21pm
Thanks for the reply Doc. Is it true that an "early" 7000 was not very desirable ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2021 at 7:32pm
I don't know where you get that idea.  I never desired them because a 7040 was waaay more tractor with bigger hydraulics, wet brakes, wet-clutch, more speed selections, differential lock, and on and on. The 7000 was a nice replacement for a 190XT or 200, as it was better in every way. There was just a big hole from 106 HP to 136 HP and an even bigger hole in the features on the bigger tractor. They should have had the 7010 with an intercooler at 115 HP, the 7040 where it was at 136 HP and the 7000 at 100 HP, thus drawing a line in chassis config at over 100 HP got your the Deeluxe models.
Edited by DrAllis - 17 Jul 2021 at 7:34pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2021 at 7:40pm
I'm sorry, it wasn't meant on you Doc, I've read on other forums about the 7000 model specifically Embarrassed .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2021 at 9:17pm
So what is the list of problems that makes a 7000 a "bastard child"
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2021 at 9:25pm
From what I recall, same dry clutch as the xt/200, equal to or less hp than the above units, no parts interchanging  with other 7000 series ?? I have no proof of this, just what I recall reading on other forums .
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2021 at 9:44pm
When I was a kid I used to hear my uncles and my dad say "stay away from the maroon chassis 7000 series". Of course that was in the late 70's and none of my family owned any 7000 series at the time to base that statement on. My thoughts are that it was based on hearing about the Power Shift maroon chassis having some early failures. I believe that was cured with a shift valve change that I assume took place with the black chassis introduction in 1977-78. The plain 7000 tractors around here, whether maroon or black chassis, have a great reputation and served long hours on dairies and small farms in my area for years. I would swap my pretty nice 200 for a good 7000 any day of the week. The 200 is a better looking tractor though in my book.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2021 at 6:58am
The maroon 7000 used the same exact foot clutch as a 200, which was just fine. It wasn't just fine when it came to running a big round baler. Any dry clutch's life can never match the wet power director clutch life of a 190/200 tractor when stopping &  starting 100 times a day. The dry foot clutch never got adjusted to help increase its service life because most Owners were ignorant of keeping "free-play" in the clutch pedal, adding to possible shorter life.  I've never had one single 7000 power shift clutch failure in a maroon tractor, so that would encompass several dozens of those units in my service area over the years. As much as I dis-liked the tractor, they really had less issues than many of the larger models.  It's always funny to me how "some guy said" becomes truth when it really isn't.  I know lots of real truths about Deere tractors, but most brain-washed owners will never admit to them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2021 at 9:06am
I hear ya Doc - on how words from ppl who have no experience with the subject carry on as to be truth- My opinion on a 7000 was the 3 speed powershift is one of a kind and -rare- i guess, but id luv to own one !
Harvey/pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Harvey/pa Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2021 at 9:42am
We had a Farm Sale at a Dairy last week where there were mostly older IHC tractors and one John Deere 100+ hp cab & loader, all were well used. The Deere guys were saying all the tractors sold very high but of course the JD was really a bargain, really cheap, they were all shaking their heads but I didn't see any of them bidding...Harvey
soggybottomboy View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote soggybottomboy Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2021 at 12:37pm
On the 200, they used a seven blade fan which ran slower than the 5 blade fan on the one ninety, but still moved just as much or more air through the cooling system. There was supposed to be less fan noise which made the tractor more pleasant to drive. This fan was driven by 2 belts instead of one, and that was definitely a good thing because the belt on the one ninety had to be kept very tight or it would slip.
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2021 at 8:10pm
After operating dads older XT and my late 200, I'd never want to go back to the XT. I've got a factory cab with air that needs a little work but the heat works very well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2021 at 8:52pm
The #1 gorilla  in the equation is one never had gear jump out with a 7000 - they put a angle on the shifter teeth and collar that causes the shifter collar to pull in the harder it pulled   which was an issue if one pulled into an object and wanted to shift out of gear quickly... 7000 had a tranny brake which was almost never adjusted correctly - resulting in reverse grind out....
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2021 at 6:46pm
Again, 200 is just a refined 190XT. I still love my XT, I have no significant reason to trade for a 200. My neighbor has a gated 200 PD and honestly I like my long throw handle PD better. Its like comparing a 67 Camaro to a 69 Camaro...the 69 has hidden headlamps and a little smoother body line. Both really good cars, the 69 is a little more refined. Same with this scenario, both good tractors..200 is just a little more refined. The 4 pinion rear end od a 200 vs a early 2 pinion rear of a early XT is a significant upgrade. So that’s a big issue.
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2021 at 7:48am
Just as Dr mentioned, I've always thought it would be a cool project to build a 190/200 looking tractor using the 7000 powertrain for a 3 speed power director/power-shift.
This page was generated in 0.172 seconds.
