190xt hydraulic pump prime
youngorange2000 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote youngorange2000 Quote  Post ReplyReply Direct Link To This Post Topic: 190xt hydraulic pump prime
    Posted: 16 Jul 2021 at 6:06pm
I am installing a hydraulic pump on my 190xt that went bad last year. I have placed the pump on the tractor and have no prime. Hydraulic fluid is full of fresh fluid. I started the tractor and cranked the wheel for 2 minutes and shut it off. How should I go about priming the pump? Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2021 at 7:00pm
Pull a plug out on top and get some in there,,
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2021 at 7:14pm
Probably wrong but when I did mine I took the pressure line off the pump and ran it into a bucket I had fluid in about 2 seconds after start shut it off right away an had a couple quarts in the bucket hook the line back up started the tractor and rotated the steering wheel back and forth a few times haven't touched it since
Post Options Post Options   Thanks (0) Thanks(0)   Quote youngorange2000 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2021 at 9:12pm
I got it! I pulled the plug on top of the flow divider on the pack of the pump using a small funnel I would add a little oil the bump the starter 5 seconds and repeat about ten times until it took half a quart then started the tractor and then it shot a river of fluid. So I shut it down put the plug back in and away it goes all functions work 👍👍
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2021 at 9:15pm
Fill suction line under pump with oil before start up will help.          MACK
