185 3 point cylinder removal
AC/DC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC/DC Quote  Post ReplyReply Direct Link To This Post Topic: 185 3 point cylinder removal
    Posted: 16 Jul 2021 at 6:03am
Bought a 185 yesterday, with a bad leak on the left side 3 point lift cylinder. plugged the line, but ran out of daylight before i could figure out how to get the front pin out of the cylinder for removal. It has a Year A Round cab on
Trinity45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Trinity45 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2021 at 6:45am
It is not easy, you have to get the lock pin out of the pin that holds the cylinder then remove it and they did not leave much room to get into it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2021 at 7:37am
There is a hole at bottom to drive the hair pin out. Drive a thin chisel  behind pin to start it out.                 MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2021 at 8:10am
welcome to the forum.
Also takes patience and penetrating oil
Gary(VA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary(VA) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2021 at 8:13am
For me on the ones I've done it was worth the time to remove the batteries and box to work from the front side of it.
Edited by Gary(VA) - 16 Jul 2021 at 8:14am
allisbred View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisbred Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2021 at 10:46am
Make sure it is the cylinder, we have had to replace the metal hydraulic lines on several 185’s above the lift cylinder as they wear through and leaked on the left side. Just a thought, it does sound like you have tried to narrow down the leak source already.
Edited by allisbred - 17 Jul 2021 at 5:51am
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC/DC Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2021 at 3:05pm
Thanks to all for the info. Nice to have a direction to go.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2021 at 9:34pm
x2
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC/DC Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2021 at 2:28pm
I was able to get the lock pin out this morning,armed with the info that was shared. I was getting ready to remove the battery box, but tried it one more time and out it popped. Bought my first A-C last week, between this sight and the Granite IA Threshing Bee I'm now bidding on a WC and inquiring on a WD. Wat have you done to me
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2021 at 6:15pm
Brought you to your senses
Billbob5757 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Billbob5757 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2025 at 1:40pm
I have a cyclinder leaking and I remember repairing one many years ago.  So long ago that I forgot how I did it.   I knew it wasn't that hard to get the cyclinder off.  Maybe mine is a later model or something.  After looking for the pin everyone was talking about I consulted my parts book and realized mine had a hitch type pin sticking out the front side that I was easy to remove with a screwdriver.  Battery box even had a cut out to pull the pin through.  I think mine is around an 1980 model 185.
