off the grill tonight
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Topic: off the grill tonight
    Posted: 14 Jul 2021 at 7:09pm
did a beef roast on the "Camp Chef" grill tonight. it came out AWESUM! here's how you do it: get you an aluminum pan or any shallow pan. spray with PAM, place a short trivit no more than about a 1/2 inch tall in the pan (also sprayed with PAM), place your roast on the trivit. i used a tough cut of beef, no marbling, pour a can of beef broth in, ad sum au jus, salt the top of the roast (i use no salt, it's a potassium substitute for salt), just use a finger pinch of it. grab your injector, and inject the liquid mixture into several places of the roast. cover with aluminum foil, crimp it down on the sides, poke one knife hole in the middle of the foil. light the grill, set on low and cook for about 2 hours. check it a few times in between. this roast came out fork tender and had a wonderful flavor.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2021 at 7:16pm
Camp Chef pellet grill?
I bought one a while back and I am still learning. So far, I am very impressed (with the grill, not my ability) !
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2021 at 1:44am
not a pellet grill, just a propane grill. so far i'm not impressed with pellet grills.
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2021 at 5:46am
Sounds awesome.
I have a couple questions.
What does the no salt taste like? I can’t have salt.
On an earlier post you mentioned the Blackstone. I’ve been planning on buying the tailgater. What is your opinion on the blackstone?
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2021 at 9:23am
I bought a Camp Chef pellet grill because I have had a three burner Camp Chef propane grill (with grill box and griddle) for years. It has worked well for years.
I bought the pellet grill through Home Depot for $399. I don't think it is any better or worse that a Traeger or Pit Boss, but it was a lot less expensive.
Knowing nothing about it, I bought mesquite pellets and went home and cooked steaks. I was not impressed.
My wife bought some blend pellets (hickory, maple and apple). When we did steaks using them, the steaks were great.
I have since done chicken and a pork roast. I love the fact that you set the temperature and smoke level and pretty much forget it. The pork roast was on 275 for 6 1/2 hours and it was absolutely delicious. By far the best pork roast I have ever had.
The chicken never flared up and was thoroughly cooked, but no burning. It literally fell apart when we were eating it.
Shameless, I think you would like the pellet grill, if you tried it.
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2021 at 10:23pm
I think we all need to head for OK shameless house for samples 😀. Sure sounds great.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2021 at 11:34pm
Thad...it tastes just like salt, and it doesn't take as much of it to get the flavor level of salt. there is a new version on the market now too called "nusalt". it is also a potassium based. an 11 oz container of "noSalt" lasts both of us about a year. we had salt and pepper shakers at work for everyone to use everyday. when the salt shaker ran out, i refilled it with "nosalt" and no one could tell the difference. i remember the salt shaker running out again (it was a small one and used by 30+ people) and i was gonna fill it again with the "nosalt" when one of the ladies said she wanted the real salt like what was in it...she had no idea she was eating the "nosalt" all that time!
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2021 at 11:43pm
WF...i have been around the pellet grills alot, most my friends have them of various brands. they work great if the pellets stay dry and for folks that don't wanna tend them. what fun is that? around here the high humidity makes the pellet swell and then they don't want to feed very good. the pellet box needs to be emptied after each use and that's a pain in the a$$ to do each time. i've also tried all the different types of wood for smoking, and the apple works best on everything second with hickory. my smoker is outside and the grill is inside.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2021 at 11:54pm
Thad...the "blackstone" is a good grill, it's just un-handy. if you have your grill built in or placed in one spot on your patio or deck, you have to pull it out to get behind it to clean the grease container. the container needs to be cleaned after each use if grilling fatty foods. the "campchef" has shelves and wheels, the "blackstone" doesn't.  the "blackstone" has a larger advertising diversity than "campchef", that's why it's about all you here about, kinda like them weed green tractor wanna-be's! also...the "blackstone does not have the grill under the flattop like "campchef" does. it's just the flat top for the same/more money.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2021 at 12:03am
did home made meat balls on the grill tonight. cooked the same way i did the roast above, they were awesum! home made meaning: 82% ground beef, with diced red bell pepper, diced onion, mushroom slices and black olive slices and a few sprinkles of grated  parmisan cheese mixed in, made into balls. placed into an aluminum pan with the beef broth, i didn't use the trivit nor any "nosalt", but did ad some au jus to the broth. ya'll will read in my posts about cooking with different soups.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2021 at 1:50pm
You're sure making me hungry!
That's about the same way I do my roast.
I never thought about doing meatballs in it.
I'm gonna have to try that!
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2021 at 7:18pm
did breakfast on the grill tonight. chopped taters, bacon, eggs and zuccini.
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2021 at 8:10pm
Chopped taters? You mean hash browns?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2021 at 8:13pm
what size are the meatballs? Golf ball sized? Tennis ball? Baseball? Softball?
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2021 at 8:37pm
between a golf ball and a lemon in size. can make them any size you want.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2021 at 8:40pm
chopped taters...well yeah i guess...i cut them up in quarters and slam them thru my onion dicer, or just cut them with a knife about a 1/4 inch size pieces. i think you can buy them like that frozen, i like them fresh cut.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2021 at 8:41pm
i do make my own hash browns too, the shredded style. i always leave the skins on.
fixer1958 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fixer1958 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2021 at 6:20am
What is a short trivit?
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2021 at 5:06pm
a trivit is a thing you put between the meat and the hot. helps keep meat from burning on the bottom. can use lots of dif things for a trivit. just make sure it won't melt in the heat. sometimes i use a metal cookie cutter for a trivit
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2021 at 5:08pm
i'm doing another rib eye roast for tonight. heat is on the lowest setting, is smelling real good in the cave right now. should be done in prolly another 30-45 mins.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2021 at 8:29pm
did flat iron steaks with sliced red taters tonight. had to drive 50 sum miles to get them flat irons. the store had buy 1 gits one free, so we loaded up! i spent the afternoon shink wrapping them with the food saver. sure saves lots of room in the freezer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2021 at 8:31pm
did burgers last night. cooked up sum onions on the grill first then added them to the burgers
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2021 at 8:32pm
also bought sum bison beef, we'll have that thru the days ahead.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2021 at 8:51pm
not off the grill, but did a pork loin in the smoker, apple wood for the smoke. 2 hours on the highest setting and it's done (from frozen solid) i did sprinkle some SPG on the loin before closing the door, not alot but just a hint.
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2021 at 9:01pm
Now I see this...just finished supper about 30 minutes away!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2021 at 10:51pm
Ya stayin over for the night?  See ya tomorrow sometime.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2021 at 9:23pm
again...not off the grill tonight...cept the bacon done earlier this week...had BLT's for supper. fresh towmaters out of our measly garden!
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2021 at 10:25am
Specking of your garden did you plant it on a wagon like you where talking of?
Ours is all in old water troughs or tubs the cattle minerals came in. But my Wonderful has been to kind to the wildlife and besides doves, quail, and turkeys, 3 or 4 does and their fawns been hanging in the yard. So one has decided to have a snack as well as water. Pulled a minni pumpkin out by the roots, and a little spice of hot pepper leaves.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2021 at 12:35am
Lars....chopped taters are little squares cut from the taters. i slice them one way then turn them a 1/4 turn and slice them again, then turn one more time and slice again, watch out when using a sharp knife, them taters git a little slippery.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2021 at 12:39am
Ray...i just got me a wagon gear, i hafta shorten it up some, it was used as a header trailer. i'll start building it soon, should be ready for next year, gotta gather up all my old sheep tanks, may hafta make a few beds, that's o-k as i have the lumber for them if needed.
This page was generated in 0.174 seconds.
