WD45 lift arm lock?
twinson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote twinson Quote  Post ReplyReply Direct Link To This Post Topic: WD45 lift arm lock?
    Posted: 07 Jul 2021 at 9:34pm
Is there a way to lock the lift arms at a set height?  Mine drift up and down as I try to set a height.  The hold position is so small on the lever.  I have the traction boost unhooked.  My valve is turned all the way in on my regulator (top of hydraulic pump?  Just wondering.  I would prefer a pull rotary cutter, but had to use a three point with no center link.
Edited by twinson - 07 Jul 2021 at 9:39pm
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2021 at 10:14pm
Use a mechanical stop for the height you want set. I use limiting chains to set my desired height after out raise th EDC mower and turn around drop all the way down the chains stop it from going lower.
Post Options Post Options   Thanks (0) Thanks(0)   Quote twinson Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2021 at 10:30pm
Where do you hook your chains to?  Top three point and ?? Do you have a photo?  I was worried about a chain breaking and wrapping around the PTO shaft or something like that....
Edited by twinson - 07 Jul 2021 at 10:34pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2021 at 5:53am
When the "HOLD" position is working correctly, it is located about 1/2 way on the quadrant and has a "click" or detent in it to lock it. Yours isn't set-up right if you are hunting for it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote twinson Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2021 at 7:43am
Dr. Allis, where is the actual detent located when the lever in in the middle of the quadrant?  is it on the hold valve?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2021 at 7:46am
It is indeed built into the hold valve. The front screw on the hold valve must be screwed OUT. The screw on the two plates needs to fully lock the plates together, which will make the detent work if it is functional.
Post Options Post Options   Thanks (0) Thanks(0)   Quote twinson Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2021 at 7:52am
That explains why mine is not working.  My screw is in and plate lock is disengaged.  Thank you Sir.
Edited by twinson - 08 Jul 2021 at 7:52am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2021 at 7:58am
Owners manual.
Dennis J OPKs View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dennis J OPKs Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2021 at 10:33am
You can use hydraulic cylinder  snap-on stop collars on the rams.  Work fine so long as you don't have to change your height adjustment frequently.
