Transmission Oil Temp Sensor
tthams View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tthams Quote  Post ReplyReply Direct Link To This Post Topic: Transmission Oil Temp Sensor
    Posted: 05 Jul 2021 at 3:11pm
Hey everyone!
I am looking to install a Max Tow transmission temp gauge from Amazon into an Allis Chalmers 7060 tractor. On the transmission there is a sensor for the oil temp, and then a sensor for the transmission oil pressure to keep it above 1800 RPM.
If memory serves me correctly doesn't one sensor sit towards the top of the transmission, and the other on the passenger side towards the bottom of the transmission behind the rear right tire?
Does anyone know which sensor measures what? More specifically where is the sensor that measures the transmission oil temperature located.
Thanks in advance!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2021 at 4:53pm
Trans temp sender behind the small fuel tank on the right side down low. I think it is 1/2" pipe thread.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tthams Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2021 at 4:59pm
Thanks!
