Keeping water out of air compressors
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Topic: Keeping water out of air compressors
    Posted: 03 Jul 2021 at 8:38am
Got an 80 gallon compressor ; is there any way to keep condensation / water from building up inside ?
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2021 at 8:52am
Drain it daily.
A proper air Lind with drops along a wall helps keep it out of tools as well.
My neighbor has some sort of electric automatic drain on his. It drains every morning.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2021 at 8:53am
No, but there are ways to remove it, even automatically. Need a blow down valve/ drain. You can buy them that operate on a float and blow down automatically but it’s pricey and more for places that use a lot of air, near continuous or very frequently.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2021 at 10:53am
Condensation of water in compressed air is a daily occurrence -
How to prevent it down line  from compressor is draining receiver often when in use .
 A refrigerant drier is used in industry to remove moisture ,
There are automatic dump valves with float internally that drain condensate , or like on trucks where a filter and dump valve work by air pressure when compressor starts and stops .
http://www.wilkersoncorp.com/catalog/9cw-yb-241.pdf
Boss Man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boss Man Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2021 at 11:16am
I had a timed dump valve on my compressor when I had my repair shop. The more humid the air is the more condensation you will have when you compress it. You cant remove water from hot air so drip legs and moisture traps need to be added down line of the compressor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2021 at 11:30am
An 'intercooler' installed between compressor head and tank will get rid of most of it.
On my 'todo' list. Have a Chevy air conditioning  'rad' ( 3/8" tubing) and fan ,just need the stores to be OPEN to grab some fittings and such.....
There's LOTS of homebre designs on Google...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2021 at 11:57am
So then you still need to drain the intercooler.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2021 at 3:26pm
Thanks guys,, seems just turning the drain cock is the way to go
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2021 at 4:31pm
Install a street L and  pipe to  a ball valve.
Sure makes it fast and easy to blow down condensate from the tank.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2021 at 5:49pm
Have that set up on both of mine, then added High mounted feeder tubing to areas of my shop, drain legs with valves at each to drain any moved into the lines.  Have a water separator I place inline to coalesce and drain water when use spray equipment for paint.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2021 at 7:36pm
yes, you need to drain the intercooler but then the air going INTO the tank is cool and dry.
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2021 at 3:23pm
In the tire shop we had foot operated drain valves on our compressors. Simply walk buy, step in the lever and the water drained out. Compressor in the main building was beside the drain. Compressor in the back shop drained out on a sloaping floor. Floor slopes to the outside of the building.
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2021 at 12:53am
I been contemplating this question.  The only way I can think of would be to connect the hose to the compressor itself, and not use a tank.  Then you could install a couple of drier type devices in the hose coming from the compressor head.  Probably wouldn't have much air pressure but it would resolve your problem.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2021 at 7:01am
A simple ball valve at the bottom of the tank works great. I have a 90 degree fitting with a ball valve screwed into that. In the summer, you need to drain the air compressor daily because of the warm weather. An inline dryer filter down stream will help protect the air tools from getting moisture in them. Some have a drain cock on the bottom to drain those as well.  There are quite a few ways to run your piping to help with condensation. HTH
Steve@B&B
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2021 at 2:50pm
I've got a ball valve on a 90 deg. elbow on my tank drain. I added a hose extension through the wall so it blows the moisture (and noise!) outside.  Usually drain it daily.  All my air lines to different areas of the shop are 3/4 In. copper with drops and drain valves below air couplings.  Hardly ever get any moisture out of them as there is a water trap and filter where the compressor tank feeds into the piping system.  A good air dryer is fitted to supply air to the blast cabinet as moisture will cause problems with gun, especially with the very fine glass bead I use to clean carbs etc.  Another dryer feeds the plasma cutter and any paint gun being used.
This page was generated in 0.929 seconds.
