D19 Power Steering Control Valve
KenBWisc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KenBWisc Quote  Post ReplyReply Direct Link To This Post Topic: D19 Power Steering Control Valve
    Posted: 23 Jun 2021 at 3:13pm
After cleaning and replacing O rings in my Control Valve my power steering wants to motor to the extreme right. I pulled the assemble apart again expecting I had installed the spool backwards. Not the case. I see in the Shop Manual diagram an inactive plunger which I don’t seem to have. Did I loose it or did some not have it?
What are your ideas as to what causes the motoring?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2021 at 9:23pm
May have lost a spring or plunger from control valve or misadjusted nut on control spool.                   MACK
