D-19 hyd pump
ryan(IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryan(IN) Quote  Post ReplyReply Direct Link To This Post Topic: D-19 hyd pump
    Posted: 19 Jun 2021 at 2:55pm
The hydraulic pump on my D-19 seems to, for the lack of better word, rattle whenever the clutch is out. Rollers bad? Can followers? This is really the only major problems that I need to fix before I paint.
ryan
1984 8070 FWA,1979 7060,1975 7040,1971 190,1960 D-17D,1957 D-14, 196? D-19G, 1975 5040,1971? 160,1994 R62
Tom IA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom IA Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2021 at 7:38pm
Make sure all your control levers are in the neutral position if one is in detent it will put the pump in bypass and rattle
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2021 at 8:53pm
They all rattle some with clutch out.             MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2021 at 6:39am
All D-19's make some noise when the foot clutch is released. Your issue is figuring out if the noise is normal or louder than normal. How is the pumps performance ?? A bad roller on a cam follower eventually ruins the clutch shaft. It wouldn't take a lot of work to drop the pump out of the belly and inspect all four rollers and their pins to know for sure.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryan(IN) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2021 at 3:15pm
I’ll try and take a video sometime soon and post it. It’s seems to me it wouldn’t be normal.
ryan
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryan(IN) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2021 at 7:32pm
Here is a video of it at idle. I’m pretty sure it needs taken off and rebuilt.
https://youtube.com/shorts/ip0zAwA7Cpk?feature=share
ryan
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2021 at 8:59pm
Does sound like bad rollers or loose bushings in the cam shaft...Thumbs Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2021 at 8:03am
It will be bad...………….
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryan(IN) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2021 at 9:02am
Think the shaft or just rollers and follower bushings?
ryan
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2021 at 9:04am
Drop down the pump & take pics.
This page was generated in 0.097 seconds.
