FS- 720 tiller/sickle mower
den/southern illinoi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Topic: FS- 720 tiller/sickle mower
    Posted: 14 Jun 2021 at 7:05am
Time to start down sizing as we may be selling our shop etc. this fall.
The tiller is currently set up to run 540 rpms.  We changed the gearing in the chain area to do this plus changed the pto shaft.  I have everything to convert it back to the pto speed for the 720s etc.  I can send pictures if you give me your e mail.  Asking $800.00 or make an offer.  Located in Southern Illinois.
The sickle mower is in good  usable shape.  Cuts as it should so not much more to say about it other than you must have the same mule as used for the belly finish mower to mount.  It also uses a longer and heavier lift cable on the right side which comes with the mower.  Again, I can send pictures with your emaiil address.  Asking $900.00 for it or make an offer.
Buy the pair and save $100.00 so both for $1,600.00.
PMs work best.   Den
Own 4 wheel 20, 5020 and associated equipment and 1 electric forklift. Also a 720 garden tractor, 720 Diesel. 620 and soon a 616 garden tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2021 at 1:30pm
Don't be afraid to make an offer...I may take it!!  Den
This page was generated in 0.081 seconds.
