Tractor recomendations
TomYaz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Topic: Tractor recomendations
    Posted: 12 Jun 2021 at 5:12pm
Ok so I am now an Big Time Operator orchard man as I have done by second pass of my orchards with a 100 gallon air blast sprayer in the D17....
The D17 Is just heavy enough to handle the 100 gallons...I would prefer a heavier tractor.
The hand clutch is a no go.  Because of how I spaced my trees, I need to constantly shut off and on the electric spray switch with one hand, drive with the other.  To not do so will waste a lot of spray.  Also there are times when I want to do a tree slower utilizing the hand clutch so to keep PTO going but My hand is too busy.
So what I need is a tractor that is a bit heavier, AND one that allows me to "creep" when I need to with a foot clutch (one that is built for such activity) whilst keeping the PTO going.
Is there a AC that fits the bill, or another brand?
Tom
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2021 at 5:34pm
Put the on/off switch for the sprayer on the top of the PD lever...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2021 at 5:53pm
Tongue
What I want in riding the clutch other than  the hand clutch is not to be found or not good for the clutch I suppose.   I guess in modern terms what I want is a I tractor with hydro ground speed control and independent PTO. ...Run the sprayer switch with one hand,  hydro ground speed and steering on the other.  Going slow and straight and with power steering I would think the one hand could do both.
matador View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote matador Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2021 at 6:04pm
I don't know what your budget is. If you can afford one, an International with a Hydro would probably be the cat's meow for you. If you can't, and are looking at something with a gear drive, I'd look at an old Case with Case-O-Matic (730 or 830). I bought an 830 last month and love it. You can crawl along slow in the Case-O-Matic mode, but the way that system works makes it so you can almost drive the tractor with the foot throttle like it's a car. If there's a large load, you release the foot clutch and the tractor will just sit there until you give it throttle. C-O-M is a torque converter system, so a high load with no throttle means you sit there just like you would in your pickup. It's not an Allis, but for what you're doing it might be just the ticket
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2021 at 6:33pm
Thanks for the tips!
I do have an AC175 that is not going to do the job...part it out to raise a little $$!
bigal121892 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigal121892 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2021 at 6:44pm
Assuming a tractor with CVT isn't in your budget, then I would go with Matador's idea.
Post Options Post Options   Thanks (0) Thanks(0)   Quote matador Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2021 at 6:49pm
I'm probably wrong (It's my specialty!), but the IH Hydro is the only true older Hydro I can think of. For what you're doing, a Case-O-Matic would make a lot more sense than something like a Deere Powershift I'd think. Those old Case's go pretty cheap if you can find one in decent shape usually- a lot of people don't understand how to run a Case-O-Matic (Not all 730's and 830's had it- it was an option), so they don't bid on them. It's simple, but different for sure
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2021 at 6:56pm
How about an AC 7000? Independent PTO, three shifts (low, medium, high) on the go in every gear. It's heavier than the D-17, but still pretty nimble. Reliable turbocharged 301 engine.
I loved my 7000. I think it's just what you are looking for !
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2021 at 8:00pm
Didnt realize what I was after was such a "special" feature!
I have one hydro tractor...a Deere 316 garden tractor...love the hydro feature....
Hell WF I dont know what the hell I want!  Or, watch what I ask for, I just may get it!
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2021 at 8:05pm
Oh hell thinking this through....outloud...
Let me put the sprayer switch on the left hand  next time......see if its easier....
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2021 at 8:31pm
Or maybe a peddle switch?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2021 at 8:44pm
Foot switch, yes like a real big time sprayer has.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2021 at 9:38am
Wait a minute....I was told I was buying a real big time sprayer, and I have no such foot switch!  I have been had!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2021 at 10:14am
"life lesson"
This page was generated in 0.395 seconds.
